Results 1 to 15 of 20
Thread: Pulling motor with transmission
    Jun 2007
    Woodstock Georgia
    I am pulling my transmission to swap it with another unit. I also want to fix a leak on the front cover/oil pan while the transmission is out. I want to pull the motor and transmission while they are still connected as I am limited to how high I can raise the car to get the transmission out the bottom.
    My plan is to run 2 6400 lb capacity lift straps under the intake manifold and use these as my lift point. I'm wondering if the intake would be an okay lift point to remove the 2 pieceswhile they are still together?
    04 SB MM RIP 4/24/09
    03 SB MM (the new girl)
    Mods: K&N CAI, 180° stat, SW headers, custom 2.5" h-pipe exhaust from headers to tips w/Dynomax VT mufflers, Part of the Art Carr Stage 2 tranny kit, rebuilt with Alto Black bands and clutches, deep transmission pan, big ass trans cooler, PI 3.5k rpm Triple disk TC, Dynotech 4" driveshaft, Metco Drive shaft loop and rear CA's, Addco front and rear sway bars, just a bit of powder coating, stock size performance brake upgrades, QA1 shocks in the rear with KYBs in the front, and replaced every stock suspension bushing. Tuner's Inc tuned 298 rwhp/306 rwtq
    Oct 2008
    Ocala, florida
    bump........
    Get an engine tilting device, you'll need to change the angle several times during the process of removal. Attach to the top 2 bellhousing bolts and the two alternator mounting bolts in the block.
    Jun 2007
    Woodstock Georgia
    Thank you sir, exactly what I was looking for. I was more than a little worried about trying to lift the both pieces by the intake as it is only cast aluminum. I am sure it can support just the motor but not 100% sure about w/the tranny still attached. I already have the load leveler so I will just pick up some longer grade 8 bolts and some good chains. The ones that came with my hoist and leveler don't really instill great confidence in me.
    While the motor is out I plan on making some knock off lift brackets based off pictures I have seen of the Ford ones. Already picked up some 3/8" X 3" X 24" steel flat stock for it.
    Tonight the Kook's come off and then I will have to get a buddy to help with the hood tomorrow. I am expecting to have the motor and tranny out by Thursday night.
    Quote Originally Posted by cougar9150 View Post
    Has anyone told him about the tranny cross member?
    Attach the leveller as close as possible to the intake manifold. You gotta have a lot of lift on the cherry picker, and if you get the engine part of the way out then have to drop it back down it's a real PITA. I guess if you get in that situation you could drop the car whild the engine is hanging there instead, but it's gonna take some helpers to do that. I generally do it solo.
    I don't pull my hood off to remove the engine. I just pop loose the gasprings and get a prop rod (PVC plumbing pipe is easy to cut to length) to hold the hood nearly straight up.
    Pull the cowl and wiper motor.
    Jun 2007
    Woodstock Georgia
    I have the factory manual, so I know about the cross member.
    Maybe this won't work for me then, I'm not sure if I have enough clearance to get the hood all the way up straight. I only have 8 foot ceilings in the garage so I may just have to lift the car higher and pull the tranny from the bottom.
    Hate to do it this way but I think unless I disassemble the whole front end of the car I will probably have to pull them separately due to height limitations in my garage. I'll take a better look when I get home but I starting to think I will have to do it the PITA way.
    The manual tells you it's there and that you have to remove it, but it doesn't begin to describe how hard it is to pry it loose after the bolts are out. I use a crowbar.
    Don't forget the BFH!
    Jun 2007
    Woodstock Georgia
    Never had one that was easy to get out on any car before. My Cougar and every Stang I have ever worked on took both of these specialty tools. BFH and a crowbar are your friends on these type of jobs.
    Nov 2009
    Connecticut
    Why not remove the engine first, then the transmission?
    Personally, if I was going to separate them I'd do the tranny first. You can pull the tranny with headers still installed, then with the tranny gone at least a few of the header bolts will be easier to get to.
    you cant pullt he motor with the headers?
    Yes, BUT...
    One of the 2 times I did it I cracked the heater housing. Between that and the wrestling match to get it installed, I decided to just pull the headers every time since then.
    Yes, BUT...
    damn it, those things were a ***** to get on, i really didnt want you to tell me that
  1. Pulling off Tires
    By murphypeople in forum Tires & Wheels
    Last Post: 03-15-2007, 07:09 AM
  2. TransMission
    By davidholland in forum Test Forum
    Last Post: 07-24-2006, 06:43 AM
  3. Finally pulling the trigger
    By Bubba Hyde in forum Community Discussion
    Last Post: 07-19-2006, 08:26 AM
  4. 460 Ford Motor (1972 Police Intercepter Motor)brand New!
    By hitchhiker in forum Community Discussion
    Last Post: 01-03-2005, 08:14 AM
  5. Code pulling
    Last Post: 05-09-2003, 12:45 PM
