Results 1 to 15 of 24
Thread: Cylinder 5 code PO355
    Mar 2011
    Newport News, Virginia
    It says ignition coil E/Secondary Circuit Malfunction...
    Im hashing this problem my car shakes in drive and reverse only when I stop for about thirty seconds and stop but it doesn't shake in park, neutral, or when the a/c is on I can't figure out what this problem is so I put the car in the shop and at first he told me it was the ecm come to find out it wasn't, he changed the COP connector,battery connector, alternator and computer. And still didn't fix the problem he also did a compression check on that cylinder and he said it's not the engine it's an electrical problem somewhere....I'm so lost someone please help
    Swap the coil and plug from cylinder 5 (front-most on the driver's side) with any other one...see if the code follows.
    Mar 2011
    I swapped out the coil and plug and it stopped for a little while but came right back
    Came back on cylinder 5? Sounds like a wiring issue...see if you can trace the wires from the coil to the PCM.
    Mar 2011
    Yep cylinder5
    North Aurora, IL
    How come when I google PO335 for Ford and Crown Vics/Marauders etc etc, it comes up as a camshaft position sensor issue?
    Sent from The White House on taxpayers dimes.
    DTR + 4.10's + Eaton swap = Wreeeeeeeeeeeeeeedom
    Great quotes!!
    Eat poo poo and die heathen.
    Because the OP has code P0355, not P0335.
    Hiram, Georgia
    Then again, what's a digit or two among friends?
    North Aurora, IL
    Because I'm a butthole. LOL I should have gone to bed LOL.
    Great quotes!!
    Dyslexic you are?
    North Aurora, IL
    Dyslexic you are?
    I had taken my muscle relaxer and pain meds before I typed what I did. LOL.
    Great quotes!!
    Sep 2013
    Aurora, Illinois
    Quote Originally Posted by Keith.Williams View Post
    Did you figure out what the problem is? I now have the same code, changed the coil and plug also, and still can't figure it out. I thought about the ECM, but you said, It wasn't that. I'm just curious if you've had any better luck. This didn't start till I had a car wash at Delta Sonic. They did an undercarriage spray, and I'm wondering if it messed up some wiring.
    Buying things I don't need, with money I don't have, to impress people I don't know!!!
    Production #1489 of 3213/#516 of 997
    Mar 2011
    No I still havent found the problem, the car drives fine but when I put it in drive or reverse it tends to shake for about 30 sec and stop but it doesn't do it in park, neutral or when the a/c is on so now im thinking of a vacuum leak
    Sep 2013
    Aurora, Illinois
    Is your CEL still on? I finally got mine back, but I had multiple problems. Here's something you might want to look into. I had the P0355 code going into the shop. Mechanic says, he scanned it and got P0325, n P0326, which is the knock sensors. My Actron scanner didn't pick these up! He put new ones in, and it runs perfect now. Well, that and him fixing the other codes I had. Anyways, I asked about the P0355, and he said, It was a dummy code brought on because of the knock sensors. Hence why the new coil, and the new plug didn't work. I'm not sure if that's your problem. My car was running like crap!
    Mar 2003
    Las Vegas, NV (Henderson)
    The wires for cylinder #5 run back along the top of the engine to behind the left cam cover. Then down and to a big connector held together with a bolt in the center right under the power brake booster. From there it runs over the PCM connector between the brake booster and inner left fender. If it happens when putting it in gear, this rocks the engine slightly and may be moving the harness enough to cause an intermittant open or short.
    Vislually inspect the harness along the engine and especially where it runs along the back driver's side of the engine. The bracket that holds the windshield wiper assembly in place has a sharp edge along with the area in the back of the head. The engine harness passes very close to these areas.
    While the engine is running you can gently tug and shake on the harness from cyl 5 to connector and to the PCM and see if it causes the problem to occur. This may give you a starting point to check that are of the engine harness.
    1 of 111 Without Heated Seats
    6 CD Changer in Trunk
    Locking Lugs
    Trunk Organizer
    Marauder Side Emblems
    Rear Bumper Inserts
    Nephews: Blue w/Light Flint
    Born 02/05/03
    2011 of 7838
    Locking Lugs
    Trunk Organizer
    Factory Alarm
    Rear Bumper Inserts
    6705 of 7838 2003's
    Built Friday 02-07-2003
    Bought 09-10-2012
    #5 2003 DBP/Light Flint
    6741 of 7838 2003's
    Built Tuesday 02-11-2003
    Bought 05-06-14
  1. Wanted To Buy In Need of a new cylinder head
    By marauder'10 in forum Marauder Parts/Misc. Wanted
    Last Post: 05-09-2012, 04:57 PM
  2. misfire code P0302 (cylinder 2)
    By lifespeed in forum Shop Talk
    Last Post: 11-25-2010, 11:34 AM
  3. cylinder #`s ?
    By mohammed in forum Shop Talk
    Last Post: 05-12-2009, 04:44 AM
  4. wtb cylinder heads
    By ImpalaSlayer in forum Marauder Parts/Misc. Wanted
    Last Post: 03-01-2009, 08:28 PM
  5. Misfire cylinder #8
    By Johns_goat in forum Shop Talk
    Last Post: 01-23-2008, 06:36 PM
