hey guys, I have come to a cross roads and need to sell the marauder. I have trilogy number 195 showing 148k on the car. The motor was replaced with a well documented motor on this site and has about 10k on it now. When the motor was replaced the blower was sent to magnuson for a full rebuild. The interior is nice and the paint looks great but does have some chips on the front bumper cover and a small ding in the passengers rear door. The work that was done was performed by Mo's speed shop and Marty has agreed to inform anyone needing to know that. Here is the info on the car
motor
cp pistons cut to 9cc for 9.3 comp./20 over
manley hbeams
mahley rings
king rod and main bearings/arp studs
block was plate bored and balanced
evenflow cooling
very extensive head and valve job
suspension
afco adjustable struts and shocks, metco upper and lower controls also watts, coil over front (adjustable), widened rear wheels, ford racing 410 gears with 31spline axles, nitto 5' all around.
generally speaking there is a new stealth fuel pump, radiator, optima battery and on and on. Car is very nice and very presentable. Call me at 865-286-5561 or you can also check out Mo's speed shop to verify your needs on the tune and work performed. I can try to get pics or I can email pics to interested people. Was going to ask $12,900 Thank's to Marty also
Thank you, Tony
