Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Bought junkyard engine, this is what I found when I opened it up
    Jan 2016
    South NJ
    Bought a verfied 2005 Lincoln aviator engine with supposedly 104k on it. When I cracked it open this is what I found: https://youtu.be/Xbo29Y_MAzk
    Timing chain loose as a goose. Also the engine looks like the oil was not changed regularly.
    Yhis is my first Ford DOHC engine. What parts should I aim to replace, and how can I clean it besides taking it to a machine shop? Brake clean does nothing.
    I'm assuming at this point I will need an oil pump, and full timing set? Going for a new cam cover gasket set as well. At least I got a decent deal on the motor with no core charge...
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    14.33 @ 96.82 with OLD engine
    6R80 swap in progress
    1968 Chevelle
    NA/Pump Gas 10.4 @ 128 mph
    416/4L85E LSA Supercharged build underway
    Link does not work for video
    Jan 2016
    South NJ
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    Oct 2016
    abilene tx 79606
    wow now thats a loose chain!!!
    2003 cv sport marauder engine swap. then teksid 4.6 soon to be supercharged.
    Jan 2015
    Long Island, NY
    So imagine this. You "clean" it up the best you can without tearing it down completely. You dress it, install it, connect it all up and fire it up for the first time. It either smokes or knocks or is otherwise screwed up. Now you have to unconnected it, uninstall it, undress it and tear it down the right way like you should have done in the first place. Ask me how I know. it's already in the garage on a stand and partially dissembled. At the very least strip it and send the block and pistons out to be cleaned and checked. If the measurements are good you might be able to just hone it and do rings and bearings. If it looks like crap inside you have to man. You will thank me later.
    03 Black. #2824 of 7838. New motor. 4.10's. SCT with Marty tune.
    Doesn't your original engine just have a tick, or slight knock?
    Is it getting worse?
    Is it possible the tick is just a lifter tappet?
    Can you ask the junk yard for a different engine?
    Chains will get slack like that if the engine was rotated counterclockwise. (For torque converter bolt removal) spin it clockwise and the slack disappears
    I've heard of forged engine internals....but that engine is solid GOLD!!!
    Jan 2016
    South NJ
    Quote Originally Posted by Stugotz View Post
    Yeah that is on the table. Right now I am going to be doing a leakdown on this engine and go from there.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    Jan 2016
    South NJ
    I will be calling the junkyard but they only had the one 2005 motor. My engine isn't getting worse, but it's pretty damn annoying and it is burning oil. I hear the tick the worst on the exhaust port(s) of #8
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    Jun 2008
    To go along with that thought......if there was that much slack while the motor was running, wouldn't the guides/arms also be trashed? They don't look to be eaten through...hell, my car at 101k had worse guides than what I could see in that video.
    Jan 2016
    South NJ
    Who sells an inexpensive engine rebuild kit for this motor? Which timing set should I go with? Any measurable differences between the Ford set and the cloyes kit? The for kit is almost $200 more
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    there is a parts list from Zack in the Shop talk forum at the top, stickied post
    Jan 2016
    South NJ
    Looks like it's easier just to buy the Ford kit vs piecing it together like that.
    Anyone use the cloyes set?
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    Quote Originally Posted by 376shovel View Post
    There is no such thing. Working on mod motors is like big block Fords. Everything is expensive.
  1. 5w30 vs 5w20... dont throw rocks!!!
    By kj31067 in forum Shop Talk
    Last Post: 07-13-2006, 07:47 PM
  2. have you found rubberbands in your engine compartment
    By MonsterD in forum Community Discussion
    Last Post: 03-23-2006, 06:25 AM
  3. This may not be popular(concerns fuel flow)
    Last Post: 01-22-2006, 04:15 AM
  4. Power Stroke Diesel Owners,....
    By MM2004 in forum The Lounge
    Last Post: 12-14-2005, 09:01 PM
  5. The Prowess of the V8 Engine:
    Last Post: 01-15-2004, 03:41 PM
