Results 1 to 15 of 30
Thread: Take a look at these rod bearings!
    Jul 2011
    Bay Area, CA
    After developing what sounded like a nasty knock, I decided to pull the motor.. was almost positive it was rod knock, but to my surprise the bearings looked pretty damn good. However there is some marking on these as you can see..Just wanted some opinions on whether this is normal wear.
    98 P71 SOLD
    Jul 2011
    Bay Area, CA
    Oh and also if someone can verify this is the correct 8 bolt flexplate that would be great...! I think it is but it seems there was alot of controversy over it
    https://www.amazon.com/gp/product/B0...0ie=UTF8&psc=1
    98 P71 SOLD
    Oct 2010
    That's the correct 8bolt flexplate , however there was an issue with the torque converter bolt holes properly lining up , i had to enlarge the bolt holes on a install i recently did , not a big deal as long as you catch it before the motor goes in.
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Quote Originally Posted by Chayton View Post
    [IMG]https://gm1.ggpht.com/DtgglV8koZ4S6xCZfUYEtPbcTdTiz9 SVABdjTw_uVcS0POA3t0n94oqy8HvS BSu3tWyX8bWQYsUmmq7VZludX7MnLN riJPUM7M8OkHRgl9ox1xa-4XVZc9Mq83DBSH6WsVXA_5arXaThxH tHaZ5_Msb2HWV2kJKhU4fbmytJnUxn hIqC9a7rRXUO9-HDigA_WuceX9jJ0VeoY8REKw6jUkwJ 1_MOaR9mGVZFhLY-8s7EpPhGduh6BdbsrqK87KJGPvRv1I FXKy4E8YjErzLu0N5drfBM8t-VGDzOVfZ0fqeeeBVNcF8wBGnNGT0BW vMhb0T8QPEqy57JqcMOHaZU3YYbCKz fewt09q-clWRCp22hm9VwhTAGeEAZukanA5Lvt 9rZ6dX9zbY4SAvmN4YDaPEsn2ZfGuQ fsZxdDQcb361_NABJh_ZU1oV858t-AqYeQ-lggC6XAyPMGbrSOsRGLmFtvfTjSdlz F8hA1YQmzI_DjxnJ2f8TD_Z-5_e5vCZ0RDkFCQQjo9oDvW6LxIE9-4vyw3dN7b5JfUHBrK-4ilBYdSlfRF-OhxVCN60OecOzqOP3AYoRgveJbefHj GvHxFhkhI8h41Rg7S3BgfMpj2h8Ob6 9wOJGmohTtAtx6uQ1ay66knnojGXde itUO0v88nta11_P0ri0_6SY7LMyqrN KvBZFzI1W-kwIdddKUBqJGj2LjMG5304G2YEJBg= w1280-h670-l75-ft[IMG]
    Bearing pictures failed to load. Try uploading it again
    Jul 2011
    Bay Area, CA
    Wow that's annoying. Worked when I first uploaded... I will upload shortly
    98 P71 SOLD
    Jul 2011
    Bay Area, CA
    Original post updated with photos
    98 P71 SOLD
    Jul 2011
    Bay Area, CA
    whatchall think
    98 P71 SOLD
    Aug 2014
    Bowling Green, KY
    Looks like it got some trash in there to me. Polish crank, new bearings, let it rip
    03 Marauder 300a
    392 hp / 406 tq
    Jul 2011
    Bay Area, CA
    Quote Originally Posted by Ourobos View Post
    let err rip tater chip!? sounds good to me.
    98 P71 SOLD
    I had a knock years ago in a trilogy car i bought.
    Wasn't too bad of a knock either.
    This was the bearing.
    Moral of the story: Your bearings don't look like they would cause a knock
    Jul 2011
    Bay Area, CA
    Thanks zack.. I will find out forsure today but I believe it is going to be coming from the crankshaft sprocket...Im almost positive this is what happened:
    98 P71 SOLD
    Those bearings look ok, some wear on them. I do not see evidence of trash going through, nor high detonation pings
    Since it's apart, put new rod and main bearings in it. Have you checked alll the bearings?
    Jul 2011
    Bay Area, CA
    I checked all the rod bearings, those were the worst. I dont want to pull the crank if I dont have to...
    98 P71 SOLD
    Jan 2014
    Palm CIty Fl.
    debris in rod bearing look fresh. your gear & key certainly look like culprits for debris. either gear or key has bad metallurgy or valve train is overloaded for some reason . be sure to disassemble oil pump & relief valve inspect, clean or replace as necessary. main bearing are generally much more forgiving then rod bearings. if I didn't want to pull the crank (based on oil pump inspect) I would roll a set of mains in for what's its worth
