Results 1 to 15 of 25
Thread: Rough Idle -Throwing Codes
    Aug 2010
    Southern NJ - Exit 4
    So, it's my turn.
    Started running rough on Sunday.
    Showed p0316 so I replaced the COP in cylinder 6.
    Still running rough. Started throwing p0171 so I cleaned the MAF.
    Then, showed p0301 as well as the other two codes again p0301 p0316 p0171.
    Should I be looking at something other than plugs/COPs/MAF?
    Thanks,
    Mark
    P0316 is from misfire at start up in first 1000 revs....possibly crank position sensor..where did you get change cop in 6 from?
    Bossier City, La
    P0301 is Cylinder # 1, passenger side nearest the front of the car. The other two codes are prolly related.
    You changed #6 COP? As RCM ask's, why? Misprint?
    Aug 2010
    Thanks RCR and Pat for your replies.
    Sorry, I neglected to mention that I was getting a P0306 first. That's why I replaced the COP on 6.
    I just replaced the crank position sensor (fun, fun, fun!) and now I'm getting P0301 and P0171.
    Oh, joy.
    Mark
    Oct 2010
    PA
    If there is a misfire, lose injector connector or injector itself can cause it as well. You should pull your cop, put a long screw driver in it and lay it very close to a bolt, pull your fuel pump fuse and crank the engine over. If it sparks, Cop is good. if you have a misfire and its lean, accompanied by P0171, usually its lack of fuel, meaning injector.
    P0175 is usually the code that accompanies a bad COP. Raw fuel, no spark
    Someone correct me if I'm wrong please
    SEMPER FI From York, Pa
    one of his new codes is lean bank one, might be 02 sensor. no sense in just throwing parts at it. someone with more knowledge may reply.
    Sep 2010
    Western WA
    Swap the #1 coil with another cylinder, preferably on the other bank, clear the codes and see if the miss follows the coil. As mentioned the P0316 just means that the miss-fire was detected shortly after start up so when accompanied by a random or specific cyl miss-fire just ignore it until the main miss-fire code is resolved. Ditto for the lean code, if the cyl doesn't fire it pumps all that unconsumed air into the exhaust causing a lean reading and accompanying code.
    I just picked up a 06 F250 at the state auction, it had a CEL and scanning it during the preview revealed P0304, P0300, P0171. Replaced the coil in the parking lot and cleared the codes before driving it home and it ran all the monitors and no codes have returned.
    Of course it could be a plug too so in the past I have swapped the plug to one cylinder and the coil to another and watched which one the code followed. However after never seeing it follow the plug I haven't done that in a long time.
    Aug 2010
    Thanks EMAS! I'll swap the COPs this morning and report back.
    Aug 2010
    Swapped the COPs between 5 and 1 and still getting p0301.
    Aug 2010
    Also, the plugs are new - They were changed ~3500 miles ago.
    Quote Originally Posted by WhatsUpDOHC View Post
    Did you clear the codes and have the code return, if yes, pull the spark plug, is it wet with fuel? If it's dry, check your injector.
    Trilogy # 192 / T.S. 0012
    Aug 2010
    Thanks for the suggestions.
    I have been clearing the codes with each change.
    I'll play with it some more this weekend.
    Aug 2010
    Just checking in - What is the best practice for changing a fuel injector?
    Thanks again,
    Mark
    The fuel rail needs to come off in order to replace one.
    Aug 2010
    Ah, yeah.
    Got that.
    More to the point, what is done to relieve fuel pressure from the rail?
  1. Rough / Low Idle
    By arejayesss in forum Shop Talk
    Last Post: 09-26-2007, 05:54 AM
  2. rough idle, low mileage, slo start
    By fblumberg in forum Shop Talk
    Last Post: 06-10-2004, 07:26 PM
  3. Rough cold engine idle
    Last Post: 05-09-2004, 02:35 AM
  4. Missing and rough idle
    By Festus in forum Shop Talk
    Last Post: 10-08-2003, 08:17 PM
  5. Shifter Problem & rough idle / hesitation
    By capt512 in forum Community Discussion
    Last Post: 07-09-2003, 09:26 AM
