Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: TURBO MARAUDER 03-300a $11,900 Black/charcoal - PRICE REDUCTION *****
    Aug 2005
    JUPITER
    $11,900.00
    The time has come to sell the Turbo Marauder! I have lost the enthusiasm for her and need to put the money elsewhere. I have had offers from non-MM enthusiasts but I would prefer to sell her to an MM enthusiast. I am offering her at a very good price for the miles and the mods/uniqueness to leave room for the buyer to paint her or make more mods. Please be respectful and don’t make any lowball offers or silly comments.
    General info: (2003 300a w/ 6disc & trunk organizer, full size spare) with less then 57k miles on her. Within the last 1000 miles she has new rubber on all 4 corners, Cooper Zenon RS3 235/50 r18’s front and Dunlop 255/55 r18’s rear, fresh syn oil change (10w-30) and new thermostat. FYI coolant is 70/30 water/glycol for you folks where stuff freezes!
    I had her detuned a bit a few years back (Scott Beer) for daily drivability, no dyno but she generates about 490/560 hp/torque at the wheels at 9.5 psi still on the stock motor. Mechanically she is excellent. Driven every week. She has the common head tick/smoke at startup issues of the early MM’s. .Interior is excellent, exterior is the crappy early issue paint with some scratches I will show in pics. The Tinting needs replacing also. No wrecks and I can PM the VIN if someone wants to run a carfax.
    Because of her uniqueness I would recommend the buyer have experience and access to a VERY good tuner if they want to change anything.
    I will list the mods in the next post, followed by pics as the list is long!
    Note: This is a very heavily modified daily driver/sleeper. Sale is as is. No warrantee supplied or implied. If you blow her up or crash her after you buy her that is your problem!! I will supply technical advice or sympathy though!!
    2003 300A Black MM
    Ride it like a Ford.!!
    Aug 2005
    JUPITER
    Marauder Mods
    Motor
    Stock motor W/ARP Head Studs and Granitelli COP’s
    Meizere Water Pump, Even-flo cooling mod.
    PTK Air/Air Turbo Kit – 9.5 psi (T64e 66 mm turbo with turbosmart 38mm billet wastegate & 12 psi By-pass valve) with twin fans molded into stock rad shroud.
    Eboost II Boost Control Computer - digital boost control at your fingrtips!
    AEM AFR guage, Autometer FP gauge, Autometer oil and voltage meters
    MMR oil pump
    EGR delete, PCV delete, PHP intake spacer, SCT 2800 90 MM MAF
    Moto Blue SFI UD pulleys
    Powder-coated (dark bronze) valve covers, front cover, pulley’s
    Drive-line
    Complete tranny build with BC automotive parts and valve body, plus Darrens’s technical help.
    MMX Drive shaft, 3.73 gears, ??? LSD differential, 31 spline axles
    Extra trans cooler, Larger tranny pan
    Shinie Hinie Differential Cover
    Fuel system
    Twin Focus pumps. Upgraded FPDM
    Kenne Belle FP orifice
    60 lb Injectors
    MISC
    Dynaflow Ultraflow Mufflers
    LCM repair done and headlight relay upgrade installed
    Gods head emblems trunk, grill and Steering wheel.
    QA rear shocks
    Cut ¾ coil from front spring
    PI 3500 stall torque converter
    Polk db component speakers front and rear
    Cruzer’s Arm rest
    Pillar pod (Boost, fuel, AFR)
    TCE SS brake lines, (not installed)
    Hidden Hitch trailer hitch
    Drag Radials on 17” M
    Predator tuner.
    2003 300A Black MM
    Aug 2005
    JUPITER
    [/url]
    2003 300A Black MM
    Aug 2005
    JUPITER
    Scratch Passenger door
    Scratch Passenger front quarter panel
    Real OIL-Volt Meters
    Gauge Pod - E Boost 2 contoller - AFR - Fuel Pressure
    Odometer
    2003 300A Black MM
    Aug 2005
    JUPITER
    DIRTY ENGINE COMPARTMENT TOP (so you can see turbo nesteld in there)
    Dirty Engine compartment Front View
    2003 300A Black MM
    Jun 2005
    East Lansing, MI
    Good luck with the sale man
    11.90 @ 117.5mph on 93 octane
    Igziabeher
    South Florida
    Blog Entries
    1
    I remember being their a while back when Scott Beer was tuning it. Scott had to detune it due too the sick numbers it was putting out. Sorry to hear your selling it Jay. If you ever get time stop by the Tower Shops on friday nite. Your part of the family and are always welcome.
    Jun 2008
    rockford,il
    I really want this..... Pm sent
    Nitrous, a TURBO, 4.10's, are like a hot blonde with a STD, you really want to hit it but you are just afraid of the consequences.
    Best e/t 12.7 @108mph with a 1.9 60' on eagle f1.
    best on e/t streets 12.40 @108 with a 1.6 60'<---- finally NOT faster then justbob.
    Aug 2005
    JUPITER
    Bump! OK let's get some action before I put it up on other sites!
    2003 300A Black MM
    Dec 2007
    Coon Rapids MN
    wish i was employed at the moment id buy it right now, been dying to get back in a vic, but always wanted a marauder with a power adder, i had a supercharged crown vic and pulled a stupid move which cost me my car.
    277RWHP 300RWTQ 13.54@100MPH NA
    12.7@ 106MPH with 75 Shot of pineablpe sauce
    RIP Black vic 8/7/11 may you live on as an organ donor to all the cars you inspired over the years
    Dec 2007
    Coon Rapids MN
    what state are u in?
    Sep 2012
    Florida
    He's in Florida
    Apr 2005
    The Pitt, PA
    Motor
    If this is the motor I think it is, it was built by Al Pappito of Boss 330 racing under my watchful (and grateful) eye....
    2013 Ford Taurus SHO
    #1649
    boi
    Apr 2005
    The Pitt, PA
    Motor
    If the spare is the motor I think it is, it was built by Al Pappito of Boss 330 racing under my watchful (and grateful) eye....
    #1649
    boi
    Aug 2005
    JUPITER
    Yes it is Rich!!
    2003 300A Black MM
  1. For Sale 2003 300a Black/Charcoal
    By BlownBlass in forum Marauders for Sale
    Last Post: 06-29-2014, 12:11 PM
  2. For Sale 2003 300A Black/Dk Charcoal
    By Mr. Man in forum Marauders for Sale
    Last Post: 08-21-2011, 06:13 AM
  3. For Sale 03 300A Blk Charcoal int in Pa
    By MMB03ROZ in forum Marauders for Sale
    Last Post: 03-28-2011, 07:35 AM
  4. 2003 300A Marauder Black on Charcoal for Sale in NY
    By MTAMERC9 in forum Marauders for Sale
    Last Post: 05-14-2009, 09:43 AM
  5. Black/charcoal 03 Mods 39K miles Lower Price
    By gjtcodered in forum Marauders for Sale
    Last Post: 07-22-2008, 05:59 AM
