Hi All
I recently committed to a qty of NOS Wilwood BNSL6 calipers. ----Billet Narrow Superlite Six
These are the calipers we used on the radial mount kits until the recent replacement the FNSL6 came out. I have FOUR SETS of RED calipers here.
What does that mean to you??
I'm offering up the TCE/Wilwood 13" front kit with these calipers for a lowly price of $1300.
I will also bump you to the reformulated BP20 pads at no extra cost as well as a minimal wheel spacer for good measure. All other upcharges remain the same. Shipping TBD based on location.
Plus 1: The 13" kit- $1479
Wilwood FNSL6 calipers with stainless steel pistons (6 piston)
Choice of BLACK or RED powder coat finish
TCE Radial Mount brackets
TCE spec billet aluminum rotor hats
13.1" x 1.10" directional cast rotors
Gas slotted and zinc plated
Wilwood BP20 pads
TCE spec Stainless Steel braided hose kit
All required hardware
Optional cross drilled rotor finish- ADD $135
Optional rear ss hose kit- ADD $52
This is the same 13" kit we've had for year, but radial mount and now with last years model caliper.
This is truly a limited time deal...I am also using these calipers elsewhere and when out they are out. They are limited to RED only. I am not offering them on the 14" kit due to the wheel fit issue- you'd need a fatter spacer I believe. And I'd like to move out some of my 13" brackets to be honest.
If you were on the fence, now's a good time to jump.
