rear disc pad installation
My new rear brake pads don't slide as freely as they should. They seem to fit to tight on the slides. They are the correct pads. What is the correct way to install rear rotor pads ? After you install new pads I slid caliper on rotor. Then made pad ear contact on bottom. Then slid forward the top with difficulty. Or should I have done it top 1st then push bottom ? Either way they fit to tight. Yes, I did use brake lube.
