Results 1 to 15 of 30
Thread: Torque Wrench(s)
    Torque Wrench(s)
    Guys, I am sick of using my needle style torque wrench.
    I went to Sears asking about the different wrenches that they offer (Craftsman) but none of the employees knew anything about them.
    They didn't know how to set any of them, how to make sure they are calibrated correctly or anything else.
    I am looking for a torque wrench that is reliable, good quality, and easy to use (maybe even a digital?).
    Lastly, does anyone know of a formula that converts Ft. Ibs. to In. Ibs.?
    For example, what would 90 In. Ibs be in Ft. Ibs?
    So many of you do some much work on your cars, you must know your stuff about torque wrenches.
    Nov 2006
    Langley, BC
    Quote Originally Posted by Shora View Post
    I bought my TR from Mac Tools, dial indicator setting that "snaps" when you hit the desired torque. Cost about $200 waaay back when. They guarantee it accurate for a year, then you can always have it recalibrated if needed (ie aviation mechanics) for a minimal fee.
    Check a measurement conversion site for all your formulas, there's hundreds of them. Google is your friend.
    MOD HISTORY:
    -Lidio's Xcal2 flash, JLT CAI
    12.81@107.78 Oct 02/09
    -Ventilated Block Mod
    Out of commission
    -Rebuilt with:
    -Widened rims
    Quote Originally Posted by Taemian View Post
    Thanks for the info. Will check out Mac Tools.
    So far the best one that I found is this sucker by K-Tool International
    Cannot make a mistake setting it and it works in BOTH Ft. Ibs. and In. Ibs. WOW.
    Please, if someone knows of a better one, do let me know. I want to buy a new one ASAP.
    KTI:
    Digital torque wrench eliminates the possibility of human error with a series of lights and alarms that immediately alert the user to torque readings that are "over or under" entered values. Easy to use, exceedingly accurate (plus/minus 1 percent CW, plus/minus 2 percent CCW) and featuring a high contrast, backlit LCD screen display, users press only four buttons to operate the tool: power on/off; unit of measurement (ft./lbs., in./lbs., N-m); torque target up; and torque target down. Technicians can quickly switch among three types of measurement, eliminating the need to have three separate tools.
    Oct 2008
    Toronto, ON
    Multiply ft·lb by 12 to get inch·lb.
    Divide inch·lb by 12 to get ft·lb
    Any torque wrench is going to be more accurate in the middle of it's range, than at it's extremes. So, trying to measure 1¼ ft·lb on a 0-250 ft·lb torque wrench will not work too well.
    I have a Craftsman click-type that I've had for years. As much as I use it (3 or 4 times a year) it's a good deal at less than $80.00.
    http://www.onlineconversion.com/
    90 pound inch = 7.499 999 999 8 pound foot
    Quote Originally Posted by GetMeMyStogie View Post
    Inch·lb is usually used to indicate small torque values. Any torque wrench is going to be more accurate in the middle of it's range, than at it's extremes. So, trying to measure 1¼ ft·lb on a 0-250 ft·lb torque wrench will not work too well.
    Good info.
    The one I have pictured above is rated from 10-100 Ft. Pounds. Does that mean that I should not use it for things like changing spark plugs which need to be torqued to 11 ft. ibs.?
    Fastblackmerc,
    Thanks for the info. You wouldn't have a link to that TR would you? Looking for one that easy to set. What range is yours in?
    Good info.
    Yes, I'd get a 3/8 drive torque wrench in inch pounds for that.
    Bigger wrench I'd get in a 1/2 drive.
    Fastblackmerc,
    Foot pounds:
    Craftsman Microtork® Torque Wrench, 20-150 ft. lbs., 1/2 in. Drive
    Sears item# 00944595000
    Inch pounds:
    Wrench, 25-250 in. lbs., 3/8 in. Drive
    Sears item# 00944593000
    I'd also invest in a case for $8.00. Good protection.
    Misquamicut, RI
    Sage advise.
    300A
    born 08-27-02
    Adjusted air in and air out.
    400+ timeslips.
    May 2003
    Myrtle Beach, SC
    Shora,
    I have 2 Sears Craftsmen Torque Wrenches -- one 1/2 drive and one 3/8. The big one is in a plastic Permatex case; the small one is in its orig. cardboard case. Should be able to buy BOTH for about $150 total or less.
    GordonB
    2003 MM DBP (BLUE) (300B) w/Lt Flint (Hers); htd seats, 6 CD. PCM s/w level CRD1.
    Mods:Trunk Liner from Decklid Designs, Sunroof (ASC Model 840), McGard wheel locks, Godshead badges--steering & grill (fm Ron), Mac/Marty's Fender Badges, Silverstar Headlights, FLM accs--rear spoiler, door edge guards & trunk organizer. Bob White graphics. KB Dead Pedal & Polished Alum. Pedals. M&Z rear cntrl arms. DR (Addco) rear sway bar (24mm). Pro-Gard rear close-out panel. TCE Perf. braided SS brake lines.
    Born 5/22/03 and adopted 7/21/03. One of 328 DBP for 2003 out of 7838. Build seq. nbr: 7500 of 7838. Color seq. nbr: 282 of 328.
    2004 DTR MM w/Lt Flint (His) with htd seats, 6 CD, Fact. Sunroof; born 6/15/04, adopted 7/8/04; one of 980 DTR for 2004 out of 3213. Upgraded same as Blue MM. Build seq. nbr: 3165 of 3214. Color seq. nbr: 973 of 980.
    Other cars: '00 'Vette Coupe (Nassau Blue). '14 Vette Coupe (Lime Rock Green)
    Car Clubs: MBCC
    Foot pounds:
    Inch pounds:
    Which would you use for spark plugs rated at 11 ft. ibs.?
    I like the click-style torque wrenches.
    I know it's not the best way to use one, but the minimum setting on mine is 10 ft-lb and I use it for spark plugs, intake manifold bolts, etc. You can BARELY feel the click at the low end of the range.
    I bought a 1/2 Craftsman digitork in its own hard case ten years ago or more. I am really bad at getting it calibrated however. Check the one you buy for storage settings, most but not all need to be stored at 30 ft pds.
    As much as i HATE craftsman, this has been a great unit!
    Jan 2008
    Colorado
    Exclamation Snap-on
    If you really want an electronic torque wrench I would go with Snap-on. The prices on the website are high compared to what I bought mine from my local Snap-on dealer.
    IMHO you can't beat the quality, and you get what you pay for.
    BAIR
  1. ProCharger Blower coming for MM
    By maraudernkc in forum Power Adders
    Last Post: 02-16-2017, 07:47 AM
  2. Let's talk Torque Converters
    By merc in forum BC Automotive
    Last Post: 05-18-2009, 07:52 PM
  3. gears vs tq converter
    By burt ragio in forum Shop Talk
    Last Post: 03-22-2007, 09:51 AM
  4. Trilogy top-end speed
    By TechHeavy in forum Trilogy Motorsports
    Last Post: 11-30-2005, 12:19 AM
  5. The Truth About Stall Converters
    Last Post: 01-13-2005, 08:14 PM
