Results 1 to 15 of 15
Thread: problems, problems, problems....
    Apr 2007
    Wash DC
    It seems when it rains it pours. Just had my pulleys and electric water pump installed, picked up the car, drove about 3 miles, and noticed my temp gauge was up about 3/4 to the red line! stopped, turned around, went back to the shop, gauge past the red line! I showed the guy who did the work, he couldnt understand why it was so high, thinks its a bad therm. We also noticed that we could put your hand on the engine and it felt normal, anyone had any problems with something similar to this? And is the pulley supposed to still turn the water pump? i thought the electric water pump was supposed to be turn on its own?
    Jul 2006
    Garden State
    Did your installer burp the coolant system to get all the air out? That is most likely your problem.
    Jan 2006
    Central Ohio
    I agree. Burp it again
    KillJoy
    Aug 2005
    Olympia WA
    what they^^^said......I had a simular problem and that is exactly what the problem was
    Apr 2007
    Wash DC
    he did burp it, before i took the car the first time and again when a brought it back....it was wierd though, after i went back he burped it, the gauge went down to about midway, i drove around the block, and the gauge jumped up to the red line almost immediately...
    Jan 2006
    Central Ohio
    Keep burping.
    Take the Plug out of the Crossover Tube. Run the car. Keep adding coolant until it will take no more.
    KillJoy
    Apr 2007
    Wash DC
    thanks for the help. one last thing, is the belt supposed to turn the electric water pump? i thought it being electric was supposed to eliminate the need for the pulleys to turn it?
    Jan 2006
    Central Ohio
    Electric Water Pumps do not have a belt connected to them
    KillJoy
    Jul 2006
    Garden State
    I think the pulley on the electric pump just acts as an idler. It's just there free wheeling and taking up slack.
    Apr 2007
    Wash DC
    I hope thats the case, cause on my car the belt does spin the pump...
    Jan 2006
    Central Ohio
    Quote Originally Posted by Advancedautosec View Post
    Uhhh..... are you SURE you bought an electric water pump?
    What Make / Model is it?
    How much did you pay????
    KillJoy
    The pulley on the electric pump is just an idler. You should be able to fill the coolant by pulling the plug in the crossover tube and just turning on the key so the water pump runs. Fill it up at the plug. Make sure the cap at the coolant reservoir is closed tightly. When it is overflowing, put the plug back in and clean the coolant off the belts & pulleys, then start the car and let it get up to operating temp. Burp the coolant out of the plug again by just loosening the plug a little so that all the air comes out.
    Apr 2005
    Queens NY
    A EMP/Stewart pump is still a great alternative
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    Apr 2006
    Long Island
    Quote Originally Posted by Blackened300a View Post
    and no worrys about an electric component failing ie: pump motor, wiring, relays....
    Apr 2007
    Wash DC
    im positive its an electric from Meziere. i think thats how you spell it.
  1. Power Stroke Diesel Owners,....
    By MM2004 in forum The Lounge
    Last Post: 12-14-2005, 09:01 PM
  2. Problems! Problems! Problems!
    By Go Mifuni in forum Shop Talk
    Last Post: 11-23-2005, 12:36 PM
  3. 03 Marauder black paint problems?
    By metroplex in forum The Lounge
    Last Post: 06-11-2005, 10:10 AM
  4. Customer Service, Superchargers, and Problems
    Last Post: 03-12-2005, 11:03 AM
  5. Problems Fixed Mods Installed
    By JET in forum Shop Talk
    Last Post: 08-28-2004, 11:56 AM
