Results 1 to 15 of 19
Thread: Trans DIED! Good performance 4R70W?
    First thing first, I just got an 03 Marauder last night. I put maybe 20 miles on a cruise and parked it. Took it to work this morning and 3rd was slipping. It was reving to about 3k then would shift around 45mph. After a couple miles of driving it seemed to go away.
    Lunch time came and I took the car out and 3rd slippage was waaayy worse. Drove a few miles and it wasn't clearing up. Maybe a mile later I came to a stop light. Foot off the brake, gas, revs, doesn't move. Try 1,2,D,R nothing. Cycle through again, again, nothing. Turn car off, restart, moves! Few hundred feet, slip, slip slip! 20mph 3k and going nowhere. Turn off car, restart, drive a few hundred feet, slip slip slip!! Repeat, repeat repeat for a few miles til I got back.
    So, from what I've read the trans took a dump on me. I want to do an Eaton swap in the near future so I was thinking of getting a performance transmission and having the PO install it to make up for this mess. I;d do it myself but I bought this as a turn key car that I didn't have to mess with yet. I have enough projects and I don't need another.
    Another option was to have the PO get another 4R70W most likely from a Vic and throw that in. Or get my money back. The car isn't bad. 134k miles but the original engine was ****ed by a Ford dealer and threw a rod so it has an Aviator engine with around 100k the MM intake.
    So, that said, what are some good performance transmissions? I've seen ATF-Speed mentioned, BC Auto, but no actual long term reviews that state the durability/longevity. I'm probably looking for a stage 1 around 5/600hp. I don't think I'll be going above that anytime soon. I don't mind spending money for a GOOD transmission but I want to be sure it's gonna hold up. Altho I'd rather not spend much over the $2k mark.
    Dec 2008
    South Carolina
    So the original motor threw a rod at 34k? That's a strange case with these motors unless it was very boosted and beat on which rings the bell of how the tranny went. If you know for a fact that the motor was replaced and you did not pay more then 10k for it your ok. A rebuild would be the safe thing cause you will know it will last
    Adopted 3/31/11. Sold
    03 300a black #1199
    TERMINATOR SWAP
    430rwhp. Done by mo's
    First off, did you check the transmission fluid?
    Second, if there's sufficient fluid in the transmission,what color is it, and does it smell burned?
    FWIW, start with the simple stuff first, then move on from there.
    Aug 2009
    Florida Keys
    I hope Bobbybob is reading this
    It's all BS until you can show me the time slip!
    Trilogy #36
    #2529 of 7839
    See Garage for mods.
    O bsessive
    C ar
    D etailer
    SOLD
    2014 Caddilac CTSV Wagon
    CAI
    DRs
    11.70 @ 119 mph
    505 RWHP at Mo's untuned.
    10/16 mods
    Ported blower. LTs catless mids, flex fuel kit, pulleys, badness.
    621/626 on E49 tuned for E85
    10.65 @ 128.9 SSHS16
    Dec 2008
    South Carolina
    At the first slip he should of check the fluid but after all that driving I think he cooked it
    03 300a black #1199
    TERMINATOR SWAP
    Apr 2005
    Queens NY
    Jasper transmissions come with a 3yr 100k warranty. That would be my replacement if I toasted mine.
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    Nov 2008
    St. Louis
    Return your car if you can, sounds like it was really beat on.
    If wanted to go the cheap route you can pickup used 4r70w's for ~250-300 and swap it out. There are members running JMOD'd stock trannys with 400+ hp all day. Better yet, return your car, buy mine and do an Eaton swap which will easily put you in the 400+ rwhp range.
    Ft. Lauderdale, Florida
    Sounds like they put in the wrong trans fluid...all done
    I had my trans rebuilt to "Art Carr" stage 2 by Reinhart automotive.
    it was the tightest trans I have ever felt, I drove it for 60K miles and never had an issue.
    The art carr kit is very good when installed by a real ford tech as mine was.
    Sold on 1/16/2012
    MM 2003 300A
    Reinhart Air-to-Air Vortech Supercharger #8, Art Carr Transmission, PI 3000 stall TC Triple disc, 4:10, TA Girdle and studs, Dynotech Driveshaft
    DR Xcal2 tune, Motorcraft AGSF22C Plugs(Autolite 103) Trying some NGK Iridium, New ACCEL COP's, Rear engine cooling mod
    180 deg. Thermostat, KOOKs headers, Magnaflow high flow cats (NO CATS), Magnaflow Mufflers (with stuffing blown out)
    Addco front & rear sway bars, Metco drive shaft loop, Metco control arms, ProGuard Skid plate
    Widened rims by Weldcraft w/Nitto 235/45 & 285/50, DynoPros Aluminium Door Sills
    http://www.mercurymarauder.net/forum...do=view&id=474
    Jul 2011
    Bay Area, CA
    Quote Originally Posted by boatmangc View Post
    sigh. what now?
    98 P71 SOLD
    Quote Originally Posted by bobbybob3680 View Post
    sigh. what now?
    I think he was referring to the advice some of us have been offering you relative to buying a Marauder. Don't spend every last dime you have to get a car, as you'll need some cash for repairs that may crop up. This thread illustrates what can happen, even with the very best of intentions.
    It happens, and having a nice car with no money to maintain or operate it gets old, real quick. (Ask me how I know; been there, done that...)
    Jul 2011
    Bay Area, CA
    ahhh. Yes. I understand, is good advice indeed. Thats why Im waiting till may-june to work on getting one. Although as for the op, I Dont see how these problems didnt arise during the test drive.
    98 P71 SOLD
    glad to see you over here alex
    [QUOTE=bobbybob3680;1136273]ahhh. Yes. I understand, is good advice indeed. Thats why Im waiting till may-june to work on getting one. Although as for the op, I Dont see how these problems didnt arise during the test drive.[/QUOTE]
    Agreed, you think the slippage would have surfaced earlier.
    Lentech is my choice
    Quote Originally Posted by slickster View Post
    At 134k it threw it. The Ford dealer supposedly did it. The car was dropped off not running correctly and the guy got it back not running. I saw pics of the swap and the invoice for the engine. I wouldn't have bought it just because of this but the price was RIGHT.
    Yea, it was at the proper level. Smelled like burnt crap and was brownish reddish. I'm pretty sure I smelled it cooking...
    Thanks to you and Ryan, now you got me addicted to another damn vehicle type!
    [QUOTE=SC Cheesehead;1136341]
    That's why I'm shocked. it was fine during the test drive, it was driven 50miles to my house and I drove it 20 after with no issues. It died like overnight...The PO is just as shocked. otherwise I wouldn't have bought it.
    I spoke to the guy today and this is what's gonna happen. He works for a cab company and he is getting a rebuilt transmission with under 20k miles from a spare cab and putting it in. He took the car for a ride and said it shifts great. He's gonna pick it up tomorrow and hopefully have it in by saturday night.
    BUT...what's the deal with the torque converter? Should that be changed? I was told the Vic ones are different. How do check a converter to see if it's ok? From the sounds of it(well from what I've read) it's just the actual transmission that ***** the bed and not the TC right?
    2003 Mercury Marauder- Metco Billet Watts link and Control arms, 4.10s, carbon clutches, KYBs, Trick Flow aluminum diff cover carrier bearing girdle, JLT CAI, Lidio tune, muffler delete, Granateli Connectors, Nitto 555/420s SOON to be Procharged P1SC
    95 F150 EB 351W
    93 F350 7.3 IDI Turbo Crew
    89 F350 7.3 IDI Crew Cab
    71 Kaiser Jeep XM818 Cummins NHC250
    69 Mack M123A1C Cummins V8300
  1. Car just died! HELP!
    By Marauder-Mike in forum Shop Talk
    Last Post: 05-26-2011, 04:19 AM
  2. What is the weight of the 4R70W Trans?
    By Blackmobile in forum Transmissions
    Last Post: 06-24-2008, 08:26 AM
  3. excellent info of the MM and of the 4r70w trans
    By Black_Noise in forum Community Discussion
    Last Post: 02-23-2008, 10:18 PM
  4. Replies: 17
    Last Post: 01-30-2007, 04:21 PM
  5. Sticky Tires with Good Highway Performance?
    By John F. Russo in forum Community Discussion
    Last Post: 01-09-2004, 07:22 PM
