Saturday October 16th. The gates open at 11AM. They start running at 12. Come out for some test N Tune action here in Michigan. I will be bringing the Bolt to this one. US131 motorsports park. Time to come out and have some fun.
[SIGPIC]
ΓρεεκΓοδ
Will plan to attend.
*Need to get a baseline for the recent acquistion - Goth F150.
John,Ya need to bring the monkey and get a few runs under your belt.
I just picked her up Paul. We3 will start the roll bar painting tonight. The Bolt is also getting a couple of minor changes.
[SIGPIC]
Well we made it again! The only issue was a water pump gasket on the last run. Four people drove her. Four people missed third gear! Gotta do some thing about that as I was one of them! the best time was 11.641. We all had a riot with the car. Sixty foot times when I drove it were. 1.66 1.68 1.69 so that part is getting pretty good!
[SIGPIC]
...I never heard of an issue with an FE water pump gasket. Is it under the cover, or the mounting gaskets (I use studs to help align & install the pump)?
ΓρεεκΓοδ
Dale it is just a bolt on water pump. This is the second time a gasket let go on that spot. It did last year when we first changed the motor. I have no idea why!
[SIGPIC]
Glad that things went well John. Four drivers making one run each is not going to work to resolve the missed gear problem. Look forward to seeing you in Hot-lanta.
Sherman
2003 Marauder 4.6
3.4 Whipple Crusher
Custom CAI down in bumper cover
Local built Trans with extra direct clutches (ATS Newington, VA) Circle D 3000 stall Triple plate converter
Custom Sumped stock fuel tank Aeromotive Pro Series Pump with Controller Return Style pumping E85 through ID1300 Injectors
4.10's Detroit Locker 28x10x16 Hoosier Drags on widened 16" Mustang rims, CHE Control Arms
Custom Headers with 2" Primaries and 3.5" Collectors
I made three runs Sherman. I only missed once!
[SIGPIC]
