Results 1 to 7 of 7
Thread: 04 MM ECM Unlock fail during tune attempt
    mm_micar Guest
    Question 04 MM ECM Unlock fail during tune attempt
    Purchased an Xcalibrator 2 from Alternative Auto. When I attempted to program with their tune, I got an "ECM Unlock Fail". How does one unlock the ECM. I searched this website, no mention of it (or I missed it). What gives?
    Also, what's the story on the fuse pulling exercise? Are we worried about current draw on the 12v battery or some spurius voltage spike generated from an inductive device (fan, motor)when it turns on? To pull or not to pull...?
    You dont need to pull any fuses, just press yes when it asks if the fuel system is disabled.
    Is there a chip in the car?
    The xcal will not work if you have a chip
    mm_micar Guest
    Don't know if there is a chip. Where does one look to find it? Can it be removed and the XCal tune installed?
    Quote Originally Posted by mm_micar View Post
    Look under the driver side kick panel above the pedals.
    If it has a chip, simpl remove it then load the tune.
    Aug 2006
    MA
    As Zack stated it will be an aluminish colored box directly under the steering wheel.
    445rwhp/408rwtq - 12.6/110mph
    DR Vortech NOIC #5
    Sold
    mm_micar Guest
    Angry
    Well Gents, found and removed PCM module, hasn't been tampered with (opened). So no chip installed.
    Contacted Alternative Auto, they suggested disconnecting battery and verify PCM code (MAV2 for 04 MM). If no go,return SCT Xcalibrator 2 to them for replacement.
    Returning to them tomorrow.
    Thanks.
    Jun 2002
    I thought the '04 PCM didn't have provision for a 'chip' ?
    Member Number 32
  1. 91 octane tune for my FIT/Procharger car
    By snowbird in forum Alternative Automotive
    Last Post: 06-17-2006, 05:43 PM
  2. New 4.10's and Reinhart Tune!
    By Ross in forum Tuning
    Last Post: 02-10-2006, 02:04 PM
  3. Custom DiabloSport Tune #'s !
    By Cobra25 in forum Sunshine State Marauders
    Last Post: 05-02-2005, 07:37 AM
