The OEM coil packs are a common problem on these cars. Don't assume the DTC codes (or lack thereof) will be able to identify the problem with 100% accuracy.
The funny thing is, the Ford replacements appear to be highly reliable and are a different part number so they seem to have corrected the issue. Definitely replace them all, attempting to just change the "bad" ones is a waste of effort. They are all the same flawed design. They seem to burn through the plastic case and arc at the output.
Lifespeed
