Results 1 to 13 of 13
Thread: Eatc help
    Dec 2007
    south carolina
    Eatc help
    I have been reading the sticky on the I ring replacement but would like to know how to pull the eatc out. Does the plate around it just pop off? Also how do you test to see if there is vacumm? I have some mechanical skills just like to know as much as I can before I dive in.
    Thanks in advance
    Quote Originally Posted by mherman18 View Post
    Thanks in advance
    http://www.mercurymarauder.net/forum...t=36922&page=7 Page 7, post #103, Page 17, post #253, page 26, post #382 (how to access/remove the EATC)
    http://www.mercurymarauder.net/forum...t=36922&page=5 Page 5, post #62 (how to do a vacuum test)
    The above should help, good luck with the repairs (you should be very pleased with the results).
    Nov 2006
    Union City, CA
    The trim around the EATC which goes all the way to the passenger side comes off. You open the passenger door. Grab the right side of the trim. Start to pull. Work your way toward the steering wheel.
    Don't be intimidated about the EATC o-ring repair. I've even done it.
    Dec 2007
    south carolina
    Ok Thanks I just ran the test to see if there was any error codes and got the 888. Now with the vacumm testing does that need to be done or can I just replace all the o rings becuase I dont have a vacumm guage and have never used one. Not to comfortable with it also.
    Nov 2006
    Union City, CA
    Well, when I did mine, I had no codes to begin with. Would only blow through floor and defrost. Did the repair and all was good for a few years....until the blend door actuator went out I never checked any vacuum lines so maybe others can instruct you on that.
    To remove EATC:
    Tools: 7mm socket or nutdriver & 10mm socket or nutdriver.
    1. Open passenger side door.
    2. Grasp the center dot matrix trim and pull towards you.
    3. Continue to work the center trim loose all the way to the steering column.
    4. You can unplug the rear defroster switch or leave it connected.
    5. Remove the four(4) 7mm screws holding the EATC in the dash opening.
    6. Disconnect the three(3) electrical connectors.
    7. Remove the two(2) 10mm nuts holding on the vacuum hose connector.
    8. To reinstall just reverse the removal procedure.
    Just replace the o-rings.
    Dec 2007
    south carolina
    Has anyone found the o rings at advance orielys or autozone. That way I don't have to order the ones from the previous article.
    Not the ones you'll want for a long term fix of the EATC problem.
    PM 03mmmonroe, he may have a few extras he'd be willing to part with.
    Oct 2004
    MO
    primo information, good to know!
    ncmm
    '04 Silver Birch MM 300A, build date:03/11/04, bought new 10/04 traded 8/08, 27k miles,
    '04 Silver Birch MM 300A, build date:12/23/03, bought used 3/16/12, 24k miles
    113k miles as of 8/21/19. . .
    update. . . sold 11/5/2019, 116k miles
    Visit My Old Gallery
    Dec 2009
    Ace Hardware has them, but they're not silicone.
    They're -007 o-rings, which can be found in a variety of places. The issue is most of them are either Viton or Buna-N (nitrile) and will simply deteriorate just like the originals. You really need silicone if you don't want to have to do the job twice.
    Nov 2003
    Monroe, NC.
    I will be at Jones Ford in North Charleston SC. on Monday to repair another member EATC unit and show my Dealer how to repair them to give their customers options.
    Russ
    Russ, Monroe NC.
  1. Eatc help
    By thegreat22 in forum Sunshine State Marauders
    Last Post: 07-26-2011, 10:23 PM
  2. Is there anything else I can do for the EATC?
    By 68Camaro in forum Shop Talk
    Last Post: 09-20-2010, 04:08 PM
  3. Eatc
    By TFB in forum Shop Talk
    Last Post: 09-10-2010, 06:40 AM
  4. A/c eatc help
    By Mike827 in forum Southern Marauders
    Last Post: 06-27-2010, 06:50 PM
  5. Eatc
    By Georges93LX in forum Shop Talk
    Last Post: 09-21-2008, 04:36 PM
