Results 1 to 7 of 7
Thread: Aeroforce Gauges, suggestions ?
    Nov 2012
    Southeastern PA
    Installed a dual Aeroforce gauge setup that's been sitting here for weeks. I can barely stand how much I like them
    I got the Oil Pressure sending unit with them but I haven't hooked it up yet, and I have analog Boost and Wideband A/F gauges on the pillar.
    Any suggestions ? Right now they're set for Fuel Pressure, Trans Temp, Coolant Temp and Battery.
    "Moonbeam McSwine"
    2003 DBP, fresh off an Iowa corn farm.
    "Pretty much stock, except for the blower."
    "Devil Girl"
    2004 DTR w/ Light Flint
    Every factory option - Moonroof, all that stuff.
    Blog Entries
    2
    I went with black backface and an a pillar dual pod mount.
    You can set them to flash red at certain readings such as high coolant temp.
    Blog Entries
    2
    No sound that I know of. I said flashing but I think is is steady red.
    May 2013
    Saudi Arabia
    Well it depends on you want it for a good looking or for performance ? What I mean is if you put it in the a pillar pod it kinda look bad but it's the best place to see the reading.
    But near the shifter it's kinda hard to dial the reading !!!
    Eaton M112 Supercharger
    Intercooler
    Lower intake plenum
    Coolant Intake Manifold
    TB Intake Plenum
    Throttle Body
    Cobra air intake tube
    Accelerator cable bracket
    Fuel rails
    39lb. injectors
    Cobra heat exchanger
    lower Metco pulley with hub
    Intercooler reservoir
    90mm Lightning MAF
    MAF to filter adapter plate
    Conical air filter
    Custom Gortch Brackets
    Heat Exchanger brackets
    Intercooler pump
    Intercooler pump bracket
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
    Nov 2012
    Southeastern PA
    Quote Originally Posted by BeeDamn View Post
    I like the way the pillar pods look, and would have put these there, but I already have a two gauge pod on the pillar with boost and wideband a/f.
    That's part of why I got the Aeroforce gauges - I liked the working boost and wideband gauges so much, they made the oem fake gauges seem stupid to me
    "Moonbeam McSwine"
    "Devil Girl"
    Blog Entries
    2
    Have you considered putting the boost by the shifter and an AeroForce on the A pillar?
    Fuel Pressure and Coolant Temp are the ones I monitor the most.
    Nov 2012
    Southeastern PA
    Yes, I have.
    The Wideband is the one I watch on the pillar. The boost gauge isn't critical IMO - it doesn't tell you that much, and I have a pretty good idea of what the boost is doing without the gauge anyway.
    For now, I have one of the console gauges on Fuel Pressure (top) + Coolant Temp, and one on Trans Temp (top) + Batt. (When I get the Oil Pressure sending unit hooked up, that will replace or cycle with Batt.)
    I haven't been monitoring the more specialized stuff like Spark Advance, Duty Cycle etc. because I don't know enough about them.
    "Moonbeam McSwine"
    "Devil Girl"
  1. Wanted To Buy Wtb used aeroforce gauges
    By texas1 in forum Marauder Parts/Misc. Wanted
    Last Post: 10-14-2011, 04:41 PM
  2. Wanted To Buy Aeroforce Interceptor gauges
    By FF1077 in forum Marauder Parts/Misc. Wanted
    Last Post: 02-21-2011, 11:09 AM
  3. Aeroforce gauges?
    By Windsor58 in forum Reinhart Automotive
    Last Post: 04-27-2010, 03:33 PM
  4. AeroForce OBDII gauges
    By Eric91Z in forum Reinhart Automotive
    Last Post: 03-04-2008, 11:19 AM
  5. Aeroforce Gauges Group Buy...
    By magindat in forum Innovative Interceptors
    Last Post: 02-19-2008, 09:20 AM
