Results 1 to 9 of 9
Thread: Noisy brake pedal?
    Noisy brake pedal?
    No that I finally fixed the hood squeak, I now notice that my brakes make an unpleasant noise when the pedal is pushed at slow speeds. Doesn't sound like anything coming from the rotors/pads, but maybe from the pedal/master cylinder(?). It's not really a squeak, it's hard to describe.
    Any ideas?
    NorthEast Kingdom of VT
    vacuum leak in the booster.?
    Jun 2007
    Bonita Springs, Fl.
    Is It kinda like a scrunching rubbery noise? I have the same issue. I just figured that the brake pedal arm joint thingy needs a little lube, but haven't done anything about it yet.
    2003 300A BLACK DD
    Sequence # 4569 of 7839
    Silver Inserts / K&N CAI / Drilled - Slotted Rotors
    DR Xcal2/Under drive pulleys (thank Rich)/180 T-stat
    EMP water pump / Denso irridiums (thanx Rich)
    Diamond Plate Radiator Cover and Air Dam, made by and broken in by magindat.
    Custom Embroidered SB Head Rests (Thanx Rich & Rex)
    Running with no mufflers, makes me sound fast!!
    Upgraded Sound System (John's Stereo)
    -Pioneer AVIC-D3 w/ XM & iPod
    -Pioneer Premier Speakers
    -MTX TC3001 Amp
    -MTX 10" Sub w/ Custom Box and LEDs (magindat)
    adopted 6/12/07 - 20,956 Miles
    SOLD 2/23/13 - 73,286
    Contemplating a battery handle delete
    Oct 2003
    Beaufort, SC
    Very characteristic of Ford power boosters.....sounds kind of like scrubbing two balloons together!!!
    Not much you can do about it but replace the brake booster but it will return in time!! If you look at the rod that attaches to the brake pedal it has a rubber boot on it that is the culprit.....It needs lubrication on the inside!! I tried to squirt WD-40 into it with a hypodermic needle.....NADA!!!
    I had a CV that the dealership simply cut the boot off and it was fine from then on but I'm not sure how long the seals in the booster will last with dust and dirt on the plunger rod.
    It won't hurt a thing being noisy but ain't it irritating!!??
    Marauderjack
    That's it exactly. I guess I'm only noticing it now because my AM reception has gone out, and there's not much music I like on the radio. Guess I need to fill the CD changer.
    Marauderjack
    I've never had a car with this many odd noises. Maybe I need headers and louder mufflers to drown them out.
    Jan 2006
    Port St. Lucie
    I had the same problem and it turned out to be the master cylinder ....
    2003 300A
    black
    XCAL2 (DENNIS REINHARDT)
    blue inserts
    GODSHEAD oil cap (COLEX)
    GODSHEAD badging(CARMOTORSPORTS)
    flowmaster super 40s
    silverstars
    BADGELESS GRILLE(2ND OWNER)
    DRILLED/SLOTTED ROTORS
    NAPA CERAMIC PADS
    PROGUARD(DENNIS REINHARDT)
    ADDCO FRONT AND REAR SWAYS(DENNIS REINHARDT)
    MACH 1 CHIN SPOILER(INNNOVATIVE INTERCEPTORS)
    Oct 2003
    Beaufort, SC
    Quote Originally Posted by khc3 View Post
    +1^^ on louder mufflers!!!
    Marauderjack
    Feb 2005
    Clermont Florida
    We all have it. I brought my car into the dealer three times. Once they replaced the booster and it was back in three months. I just gave up and got SIRIUS.
    Performance
    Dress
    LOC: Clermont Florida
    Quote Originally Posted by not5-0 View Post
    If you don't mind me asking, could you provide some more details?
    Thanks!!
  1. Soft or mushy brake pedal normal?
    By jefferson-mo in forum Steering, Suspension & Brakes
    Last Post: 08-03-2006, 09:46 AM
  2. Squeaking brake pedal
    By kdjlaw in forum Shop Talk
    Last Post: 06-21-2006, 05:28 PM
  3. Petals coming in tomorrow anything I need to know?
    Last Post: 08-25-2005, 05:26 PM
  4. A Knocking in my brake pedal
    By MarauderMark in forum Shop Talk
    Last Post: 10-09-2004, 06:55 PM
  5. Marauder Polished Pedals Update
    By Ladyhawke in forum Shop Talk
    Last Post: 04-16-2004, 04:40 PM
