Which one of these heater hoses should I T or Y into in order to support the rear head cooling mod without adverse effects?
2003 Marauder 300A
#2928 of 7838
Build date: 8/6/02
Ship date: 5/28/03
14.33 @ 96.82 with OLD engine
6R80 swap in progress
1968 Chevelle
NA/Pump Gas 10.4 @ 128 mph
416/4L85E LSA Supercharged build underway
The one on the right.
STAY TUNED!!!!!!!!!!
Thanks. Is that the inlet?
2003 Marauder 300A
#2928 of 7838
Build date: 8/6/02
Ship date: 5/28/03
1968 Chevelle
Don't do it. They are prone to leak and drop into your cool cover right where the wires go through and cause a misfire. I have seen it numerous times at our ford store. Not only on marauders but other ones
Sent from my LG-D852 using Tapatalk
2003 Marauder 300A
#2928 of 7838
Build date: 8/6/02
Ship date: 5/28/03
1968 Chevelle
True. But we seen it happen several times
Lots of heat back there and if you over tighten you stand a chance of leaking. As embarrassing as it is my marauder has leaked causing a misfire and is actually starting to leak again I just noticed. I just ordered new hoses.
Cooling mod to relieve rear head temp.?
Yes. I'm going to connect both sides together then go to either a heater hose or back to the upper radiator hose
2003 Marauder 300A
#2928 of 7838
Build date: 8/6/02
Ship date: 5/28/03
1968 Chevelle
Definitely install the cooling mod , and save yourself a couple of burnt , and bent valves from overheating #7&8 are notorious for this problem on the dohc motors.
2003 Marauder 300A
#2928 of 7838
Build date: 8/6/02
Ship date: 5/28/03
1968 Chevelle
I guess that's it.
