MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Power Adders
Power Adders Look here for all your centrifugal, roots, supercharger, turbocharger and nitrous technical discussions regarding the Marauder!
Reply
Thread Tools Display Modes
  #1
Old 02-14-2017, 09:15 AM
Turbo4v06's Avatar
Turbo4v06 Turbo4v06 is offline
Senior Member
Trader: (0)
Turbo Build!!! am I missing anything
Hey guys just trying to figure out if i'm missing any thing before i start this install.
Engine:
03/04 cobra block
manley forged pistons
8.7cr
96 cobra cams
stage 2 valve springs
billet gear oil pump
Fuel:
aeromotive 340
boost a pump
upgraded fpdm
60lb injectors
wire upgrade all the way to pump
Maf:
pro m
turbo:
borg warner s369 sxe
Tune:
Marty OOOOOOOOO
I'm shooting for 10psi 500rwhp at the moment.
  #2
Old 02-14-2017, 11:29 AM
Zack's Avatar
Zack Zack is offline
Turbo Marauder
Trader: (37)
It's going to take a while. You will figure out what's missing along the way. Not exactly a science to turbo Marauders
  #3
Old 02-14-2017, 11:32 AM
Zack's Avatar
Turbo Marauder
Trader: (37)
You should shop at VS racing. Good stuff cheap there
  #4
Old 02-14-2017, 11:39 AM
Zack's Avatar
Turbo Marauder
Trader: (37)
What is your planned pipe routing?
  #5
Old 02-14-2017, 12:46 PM
Turbo4v06's Avatar
Senior Member
Trader: (0)
Quote:
Similar to yours but the ex feed and downpipe will be going under the crossmember.
Sent from my LG-LS997 using Tapatalk
  #6
Old 02-14-2017, 12:55 PM
Zack's Avatar
Turbo Marauder
Trader: (37)
Are you modifying the crossmember?
  #7
Old 02-14-2017, 01:02 PM
Turbo4v06's Avatar
Senior Member
Trader: (0)
Yes slight notching
  #8
Old 02-14-2017, 01:05 PM
Zack's Avatar
Turbo Marauder
Trader: (37)
  #9
Old 02-14-2017, 01:11 PM
Seneca's Avatar
Seneca Seneca is offline
Procharged Marauder
Trader: (3)
This helped with clearance greatly, just make sure you add some bracing under the cutouts
__________________
04 mercury marauder twin turbo build under way
  #10
Old 02-14-2017, 01:14 PM
Zack's Avatar
Turbo Marauder
Trader: (37)
I really need to do that ^^^^ for my next project
  #11
Old 02-14-2017, 01:16 PM
Seneca's Avatar
Procharged Marauder
Trader: (3)
You need to come help me finish mine!!! Motivation!!!!
__________________
  #12
Old 02-14-2017, 01:18 PM
Zack's Avatar
Turbo Marauder
Trader: (37)
Quote:
Quit being lazy
  #13
Old 02-14-2017, 01:43 PM
Turbo4v06's Avatar
Senior Member
Trader: (0)
are your pipes hugging the crossmember
  #14
Old 02-14-2017, 01:53 PM
Seneca's Avatar
Procharged Marauder
Trader: (3)
Everything is back apart at the moment for the 20th time, I'll try to get progress pictures this weekend, they're about .75 for the top, mine are both 3in down pipes, there's gonna be plenty of clearance with 3in pipes
__________________
  #15
Old 02-14-2017, 02:28 PM
Turbo4v06's Avatar
Senior Member
Trader: (0)
ok, whats the dept of your notches, my pipes will be 3" also
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Build number spreadsheet a_d_a_m Community Discussion 396 01-28-2017 05:56 AM
One HELLLL of a build!! cer0413 Community Discussion 12 11-06-2016 04:45 PM
turbo kit for 03 mm pun Other Parts for Sale 11 07-18-2007 08:00 AM
Electronics gurus...how can I build this? Breadfan The Lounge 17 05-25-2006 01:09 PM
Turbo Ernie SergntMac Shop Talk 36 05-10-2005 12:23 AM
Powered by: vBulletin
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
