Paint correction is not for everyone. To do it right requires some serious smarts with decent tools.
This is how I go about deep scratchs when highly visible.
1. Fill scratch with touch up paint (small bottles with brush are found at any FLAPS), or in my case I have real touch up paint from doing my old hood.
2. Reapeat filling scratch carefully as many times as it takes to fill entirely.
3. Wetsand only the fill section with 800 grit, then 1200.
4. Machine buff CAREFULLY around any edges, fast movement, never stopping in any areas with a fine compound ( I think I normally use Mequiars 2.0, but can't remember without looking) using a foam pad at around half speed.
5. Switch to a new foam pad and repeat with Mequiars wax paint cleaner.
6. Move on to a polish of choice.
If you properly execute this, you will never see the scratchs again. Good luck.
