Results 1 to 15 of 20
Thread: Battery Light stays on!!!!!
    Connecticut
    Please have patience w/me if this has come up on the board before, but I'm just really frustrated right now about this, and I need advice from you guys. The battery light went on last week, and the voltage gauge was reading low, indicating that the alternator wasn't charging, so I took it out and had an automotive electrical place test it, and they told me that the voltage regulator was cooked, and so they took apart the alternator and replaced the regulator. They also claimed to put the alternator through extensive tests even including RPM tests to make sure that everything w/it was fine.
    Now that I've installed the alternator, the car immediatly starts right up no problem, and the voltmeter reads 14.5 volts within ten seconds of starting it. After driving the car up on the highway for 20 miles, the battery light will NOT go off.
    Now here's the part about this story that's driving me nuts......... the battery light will NOT go off even while cruising at 90 MPH, but it will go off during wide open throttle regardless of engine RPM and will NOT go back on until about 5 seconds after letting off the the wide open throttle blast.
    Is this just another case of the car's computer throwing a code that will keep the battery light on even though the problem that caused it is fixed, and will NOT change until the dealer plugs their equippment into the diagnostic port and cancell out the code???? And if this is the case, will a handheld tuner being borrowed from someone else enable me to cancell out the code if infact that's what it is that's causing my battery light to remain on even though the alternator if fixed, and the voltmeter clearly indicates that the alternator is charging just fine????
    Blog Entries
    2
    Doesn't the alternator kick off @wot? I assume it is charging at part throttle.
    Could something be wired incorrectly?
    I suggest a call to the electrical shop.
    Connecticut
    Yeah, I'm gonna call the shop tomorrow like you've said, but I'm not so sure they will have an answer for me IF infact this all has to do w/the need to have a trown code removed in the computer, cuz that's usually dealer stuff.
    The stock pulley is no longer on the alternator, so it has nothing to do w/anything cutting out at WOT like you've implied. Besides, if that were the case, it would be doing the exact opposite if anyhting. The battery light would be on at WOT, not off. When it's off, that indicates that everything is fine. But thanks for your input. At this point, I can use all the advice I can get. This has me baffled.
    LNYTUNS Guest
    SCT tuners can read/clear codes, even if they are VIN locked to another car.
    Blog Entries
    2
    I was thinking maybe they wired it backwards seeing how it is now mounted backwards and it was only on @WOT?
    Connecticut
    Don't think so. The bottom line here is that he alternator is charging the battery all the time since the voltmeter is reading a perfect 14.4 volts all the time, WOT or not. But it's the battery light that's still staying on. So I don't see how it can have anything to do w/the alternator. If it did, then it wouldn't be reading 14+ volts.
    Blog Entries
    2
    Couldn't be a loose battery ground? Sorry, Thats the last idea I have.
    Connecticut
    I don't think so, but I'll check the other end of the ground wire if I can locate it. The end on the battery post sure is tight. I thought for sure that a bunch of people would be able to jump in here to tell me exactly what the problem is.
    Connecticut
    Quote Originally Posted by LNYTUNS
    Yes, that's what I was thinking too. I wasn't positive about that though. Thanks.
    Dec 2003
    New York, USA
    You said that your alternator was mounted 'backwards' and I'm assuming that you have the Trilogy SC installed.
    Perhaps there is a ground strap that wasn't reinstalled when the SC was installed ?
    A poor ground can cause all kinds of problems and they don't necessarily show up immediately.
    Find out how many ground straps you are supposed to have, their locations, and check all of them for tightness and resistance.
    Just checking the ground terminal of the battery cable/battery connection isn't good enough here.
    If all of your ground straps are in place and secured, then I would suspect that your BATTERY has a shorted cell in it.
    This explains why the Alternator is constantly charging at 14.4 volts.
    It is supposed to regulate itself between 12.5V and 14.4V.
    Pete...
    DOB 10/31/2003
    DOP 1/2/2004
    DOB 12/11/2018
    DOP 6/19/2019
    Connecticut
    Okay. Will do. Someone in work mentioned the groundstraps as well. Thanks. And BTW, yes, I've installed the Trilogy S/Cer two weeks ago. The S/Cer in particular is great!!!! The electrical place that I brought the alternator to said that they didn't see any problem w/the alternator being mounted backwards and running in the opposite direction. they checked that too when they had it apart, and after they got it back together.
    This place is very thorough. they even ran it in both directions to check the airflow that runs through it to cool it, and they said that it running in the opposite direction flow about 66% of airflow through it as the airflow rate in the original direction, and they stsed that this should be fine.
    Orlando, FL
    Lightbulb
    Check Logan's post's on his S/C install, I remember something about an alternator.
    Oct 2003
    New Britain,CT
    Hey Billy, try taking off your negative post to the battery when your car is running, this will let you know if your alternator is working for sure. As far as reading codes with the SCT, i have one, so we could read your codes. If your going to the breakfast on sat. i could do it then, if not, possible i can look at it at work with you today, wed. im working 10-6pm, and friday 10-5. I work at bestbuy on the berlin turnpike, in newington. I can test most electrical functions with cars there, i have all my tools at work. Just give me a call on my cell if you want to make sure i'll be there.
    Frank
    Car
    2003 300A package
    Looks
    45% Legal tint all around
    Weathertech vent shades
    Entertainment
    Pioneer Avic-N1 DVD w/ navigation
    JBL BP1200.1 amp and 3 Rockford Fosgate 12" Punch stage 3 woofers
    Rockford power 2 way 5x7's
    Performance
    1/4 mile: 14.00 sec
    SCT Xcalibrator 2
    Reinhart performanced tuned @ 285 RWHP
    255/55/18" BFG tires KDW2
    Reinhart cobra exhaust
    Meziere electric water pump
    Ford 4.30 gears w/ mobile one 75w90
    Underdrive pulleys
    Tranny Cooler
    Deep dish Tranny pan
    DR Level 2 tranny mod
    MMX Drive shaft
    3000 PI converter
    Cooling Mod
    180 Thermostat
    k&n fipk air charger
    Mobile one 5w20
    Safety
    Escort 8500 x50 linked to the Escort ZR3 Laser jammer
    Custom M5 Bi-xenon headlights
    Clifford alarm/remote start
    Color Backup Camera
    Thermal imaging camera a.k.a. Night Vision
    Setina PB400 push bar
    Hornblasters Conductors special 152db trainhorn, could be classified as entertainment as well!
    Winter
    16" CVPI wheels/Toyo Garit HT Performance winter tires
    Hiram, Georgia
    Quote Originally Posted by ultravorx
    Frank
    Frank: THis may be bad advice. Some alternators do not like being run unloaded and you can fry 'em that way.
    Connecticut
    Okay, this is what I believe that I should do according to what I've been told thus far. When it comes to this electrical diagnostic stuff, there are a lot of grey areas for me. And I'm sure this will prove to be a learning experience for me. I'm going to remove the negative battery cable terminal from the battery post to check the resistence to make sure there is a good ground. This is done w/an ohm meter, and while the car isn't running. One end is contacted to the negative cable terminal while the other is contacted to the intake manifold, and there should be 0.3 ohms registered on the meter at the most. less than 0.3 is fine, but more than 0.3 hms would indicate the engine isn't grounded properly.
    if that cheks out alright, then the next thing I'll focus on is the battery, and I'll take the car somewhere to get a Load test on the battery. If that isn't thenproblem then the only other thing that I know of that it can be is that it needs to have a code cleared, and in that case forunately for me I can call Frank (aka "Ultravorx") because of his generous offer(thankyou frank). I'll let you guys know how all of this pans out. Thanks very much for everyone's help.
There are currently 3 users browsing this thread. (0 members and 3 guests)
  1. How many forum users does it take to change a light bulb?
    By 2003Marauder in forum The Lounge
    Last Post: 03-30-2007, 11:32 PM
  2. Help needed - check engine light
    By duhtroll in forum Shop Talk
    Last Post: 01-30-2004, 02:34 PM
  3. Intermittant "Check Fuel Cap" light
    By dwasson in forum Community Discussion
    Last Post: 09-09-2003, 12:38 PM
  4. great fog light mod !!
    By joflewbyu2 in forum Shop Talk
    Last Post: 02-17-2003, 08:15 PM
  5. third brake light mod...
    By JerseyVics in forum Community Discussion
    Last Post: 02-15-2003, 03:58 PM
