Results 1 to 15 of 15
Thread: 2003 750 HP Custom built Marauder
    Oct 2014
    3715 Commerce St Grand Rapids MI
    2003 Mercury Marauder
    2003 4.6L SVT Cobra Engine Assy - custom built - 2,000 miles on engine build.
    Built 4R70W Trans w/ PI Convertor
    This car was originally built by Paul's High Performance out of Jackson Michigan. It was a feature car in the Muscle Mustang & Fast Fords magazine May 2003 issue, Big, Black & Bad article.
    The car was purchased from the estate of the original owner, brought back to Michigan, power-train was removed and custom built to handle the power from a newly installed Whipple supercharger. The car was just chassis dyno'd and tuned by Paul's, ending up at 600 rwhp, which is approx 750 flywheel hp.
    The car has been upgraded with no expense spared, KVR Brakes, Metco Suspension, HAL Adj Shocks & Coil-overs, Fuel Delivery System, etc etc. The list goes on!
    If you are seriously interested in owning a one of a kind monster, this is your car! The ultimate sleeper!
    For serious inquires only, please reply by email, and I will provide contact information to view the car by appointment only. No trades, reasonable offers considered. 517-937-1488 Mike Jackson Michigan
    Please provide a price.
    Aug 2008
    SW MI
    Price? Miles?
    If a million people believe a foolish thing, it is still a foolish thing.
    ~ Anatole France
    2004 DTR 54k, Dark Charcoal, heated seats, moonroof, trunk organizer.
    Mods: K and N intake, Lido tune, Pro Guard rear bumper, stainless bumper inserts, res delete tips, misc
    UncleLar's first DTR
    2004 Ford Crown Victoria Sport 100k, black, Dark Charcoal, stock and a zero option car.
    Blog Entries
    2
    ".... 600 rwhp, which is approx 750 flywheel hp" - That is incorrect. The parasitic loss caused by the driver train is 60hp resulting in 660 fly wheel hp.
    Nov 2012
    DC
    More pics would help
    Rockford
    Question Huh?
    Not sure what driver train you came in on but 17-20% barometric loss for automatic is the correct information!
    Jul 2006
    South Haven, Mich.
    I have seen the car and it is nice!
    [SIGPIC]
    Sep 2010
    Rome, GA.
    Quote Originally Posted by Bradley G View Post
    Maybe if your tires are about flat. Everything I've seen shows 60-70hp lost in these automatics. It would be my opinion also, 660-670 flywheel hp.
    Chris Stewart
    03 Marauder
    Paxton 2200
    20" wheels
    637.21rwhp
    538.59rwtq
    04 DTR Son's car
    4.10, K&N CAI, Jeff tune
    Headers, underdrive pulley
    297.26 rwhp
    312rwtq
    06 F-150 Supercrew Lariat 4x4
    305/55 20's
    May 2013
    Saudi Arabia
    Eaton M112 Supercharger
    Intercooler
    Lower intake plenum
    Coolant Intake Manifold
    TB Intake Plenum
    Throttle Body
    Cobra air intake tube
    Accelerator cable bracket
    Fuel rails
    39lb. injectors
    Cobra heat exchanger
    lower Metco pulley with hub
    Intercooler reservoir
    90mm Lightning MAF
    MAF to filter adapter plate
    Conical air filter
    Custom Gortch Brackets
    Heat Exchanger brackets
    Intercooler pump
    Intercooler pump bracket
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
    Rockford
    It's going to be a percentage , 600 RWHP+ 17-20% = closer to the op's claim
    Quote Originally Posted by BigM460 View Post
    The theory is that once the loss has been taken out of the equation, no amount of additional, or less hp for that matter will change the original loss. I.E. Same trans, driveshaft, and rear.
    It's really not even a percentage of anything, rather a given load for that particular car that won't change.
    "Since 2004"
    Blog Entries
    2
    Incorrect. If I put a 1,000,000 CHP in the Marauder it will take 20% or 200,000 HP to turn the drive train? Why would the drivetrain "drag" majicaly increase to 200,000 HP?
    Assuming Fords advertised CHP of 302 vs DynoJet RWHP on stock Marauders of ~242 = a drive train "drag" of ~60HP.
    Assuming no dramatic increase in RPMs the drivetrain does not increase "drag" with the amount of HP.
    Cape Cod
    This OP has not logged in since the initial post on the 11th. Obviously they're not watching the discussion.
    Oct 2014
    You will lose approx 20% of hp from the flywheel to the rear tires, through a 4R70W and 4:10 gears. The Marauders & automatic Mach 1's have always been in the 18 to 20 percentile. The stick shift cars are 15-17 percent. This motor was built looking to make 725 to 750 hp with the compression, cams and Whipple blower. It came in actually more than we were expecting.
    Blog Entries
    2
    You do not lose a %, you lose the amount of power it takes to turn the drive train and that amount is ~60HP.
    A % has nothing to do with it.
  1. Custom Built Hood Pictures
    By fairlane347 in forum Community Discussion
    Last Post: 08-21-2017, 04:47 PM
  2. For Sale 2003 Marauder, 28k miles, Vortech Supercharged & Intercooled, Built Teksid Block
    By MidnitMarauder in forum Marauders for Sale
    Last Post: 01-30-2014, 09:15 PM
  3. Replies: 12
    Last Post: 05-30-2012, 09:43 PM
  4. For Sale Fs completely built/custom marauder
    By watchurstep in forum Marauders for Sale
    Last Post: 06-29-2010, 04:08 PM
  5. 2003 STAP meet & tour! Come see how your Marauder was built!
    By Mtl_CV in forum Community Discussion
    Last Post: 12-01-2002, 10:26 AM
