Originally Posted by
MOTOWN
Plenty to choose from B&M , TCI , Uhaul pan , I have a Mag Hytec double deep pan a bit pricey but extremely nice!
I'll second the Mag Hytec pan, increased capacity, good ground clearance (if you don't get the super-deep model). It features excellent construction and serviceability with a magnetic drain plug, at a higher price.
If cost is an issue you can do the U-Haul pan and get the serviceability of a drain plug without the cool factor of rigid cast aluminum cooling and extra capacity.
Lifespeed
