Originally Posted by
Jamie R.
Well no change in my po340 code. I put a new alt on and still have the code and typically on third cranking cycle. The car idles very smooth and revs smooth but I still get the code. I didn't remove the harness for this swap, just laid the wires over to the side. I've never had this code before until using the swap brackets and marauder sensor. If nothing changes in a couple days of trying something else then ill have a set of Terry's heavy duty brackets for sale cause ill be going to the term setup with the pulley bridge. A bud of mine used this same setup on his cobra with a marauder sensor and has never had this code so I'm at a loss as to why this code keeps popping up for me.
Jamie R.
