FORGED PISTONS !!! Questions ???
Hi I know I ask a lot and I have this hard question that i want to ask you guys..
I buy the car and I has been told by the previous owner that the internals is forged !!! he said that he changed the pistons to a sporty one !!! and he said that the car has a sporty or stronger CAM too.!!!
My question is, How to identify that? I mean how to conform that the car have a forged rod and piston ? is there another way rather than taking the engine down and pull it apart ? if so, Does the forged pistons have some mark or an unique thing to tell !!!
And anybody now how much the all forged pistons and rods weight ?
sorry for my questions but i'm thinking to go S/C with more boost and I want to know if it's safe to go +450whp.
THANK YOU
Eaton M112 Supercharger ✓
Intercooler ✓
Lower intake plenum ✓
Coolant Intake Manifold ✓
TB Intake Plenum ✓
Throttle Body ✓
Cobra air intake tube ✓
Accelerator cable bracket ✓
Fuel rails ✓
39lb. injectors ✓
Cobra heat exchanger ✓
lower Metco pulley with hub ✓
Intercooler reservoir ✓
90mm Lightning MAF ✓
MAF to filter adapter plate ✓
Conical air filter ✓
Custom Gortch Brackets ✓
Heat Exchanger brackets ✓
Intercooler pump ✓
Intercooler pump bracket ✓
Ribbed idler pulley ✓
Belt tensioner ✓
Alternator Pulley ✓
Fuel Pump ✓
EGR delete kit ✓
New accessory belt ✓
Cooling tube ✓
IAT sensor ✓
