I got some dark tail lights coming in the mail soon was seeing if there is a brighter bulb I can buy so I don't get stopped by the po po
2003 MM 300A
#738 of 7,838 BLK
Build date: 6/6/2002
Adopted: 2/05/2013
MODS:
Metco control arms, Addco sway bars, TCE brake lines, Gatorback belt, remote start, underbody lights, custom doorsills. Black with custom silver hood stripes (S-55 theme)
2004 CV LX SPORT
ALL BLACK, 6 DISC, TUNED MZT
Adopted on12/09/18 from chief455
COMING SOON-Trilogy #005 THANKS CWright-
I am afraid you have awakened a sleeping Giant
http://www.mercurymarauder.net/forum...=view&id=14156
BIG BIG thanks to the GOD of marauder parts ( Darren) I am the 1st winner of Darren bag of fun give-away
VLEDS?
'21 F150 XLT 5.0 Sport
'18 Chevy Malibu Redline
'10 Harley Ultra Limited
'08 Kawasaki ZX6R
'03 Grand Marquis(sold)
Email Fastblackmerc he can fix you up.
I added 2 more bulbs (switched to all Sylverstar bulbs as well) like seen in this thread : http://www.mercurymarauder.net/forum...=silver+shades
I have tinted rear tails and have no problems with this set up.
#3538 of 7838Trilogy #238Build date:8/14/02 - Bought:4/5/07
You will also need to have a red reflector towards the rear if you are tinting your lights and are worried about being stopped. The easiest is get a license plate frame that is also red reflector.
2004 CVPI
Yes , V-LEDS is the way to go.
here is the link
http://www.vleds.com/shop-bulb-numbe.../3157-red.html
VLEDS and done!
STAY TUNED!!!!!!!!!!
Are these plug and play or is there a resistor required?
Excess in Moderation.
Sprinkles are for winners.
Yes they will. From VLEDS website:
Turn signal issues with LED bulbs
LED turn signal lamps will not flash with thermal flasher units due to their extremely low current draw. Some cars indicate this by increasing the flash rate of the turn signals, some do not flash at all. This can be remedied with load resistors wired across the turn signal bulbs to simulate a filament bulb load. One way to test this is to pull out one of your blinker bulbs. If you get a bulb out warning or rapid flashing, you will need load resistors.
Load Resistors:
A 6 Ohm, 50 Watt resistor can be connected across the turn signal wire to simulate the load of 1 regular filament bulb (2 Amp load), a 3 Ohm 50 Watt resistor can be connected across the turn signal wire to simulate the load of 2 regular filament bulbs (4 Amp load). This will solve LED related turn signal problems such as hyper flashing, no flashing or burnt out bulb indications.
ELECTRONIC LED FLASHERS
This problem may also be remedied with an electronic flasher, these units are not available for all makes of vehicles. Many vehicles have two blinker units, one for hazard and one for turn, so locate both by sound output. It is not always necessary to replace the hazard flasher.
Is there an electronic flasher that fit Marauders? rather than use resisitors
Something to think about....
When I went all LED in my Marquis (high mount too) the cruise control wouldn't work. I had to wire in a 194 bulb to the trunk wiring to the high mount to make it work again.
