I have read posts about engine noise all morning and I can't find anyone that seems to have same problem although I'm starting to form a diagnosis from the various stories. Here's mine:
In the morning or after sitting for a few hours, at start up the engine rattles (sounds like valve train with no lubrication). Lasts for 2-4 seconds. You can watch the OP gauge climb up to normal and about 1/2 way to normal pressure, the sound goes away.
It does not happen if the engine is warm. It does not happen at any other time than a relatively cold start up. Running factory specified oil and filter - always have. No leaks, oil level is dead on. First thought was oil pump issue - but nobody is talking about that.
Everybody is talking about chains and tensioners but absolutely no issues except at start up.
Has 90,000 easy miles. I grew up working on engines but have never gone too deep into this thing. It's my daily driver. Everything in my gut says oil pressure problem.
Where do I start guys?
Tom
