Results 1 to 10 of 10
Thread: Spark Plug Torque - Ford Escape
    Feb 2006
    Rosemount, MN
    I'm going to change spark plugs on my daughter's Ford Escape this weekend. It has the 3.0 DOHC V6 and I believe it has aluminum heads, so I assume the spark plug torque would be the same as my Marauder at 10-12 ft/lbs? Can someone double check for me? Also, what the gap should be?
    Thanks,
    Curt
    Have you bought the spark plugs yet? If not the auto parts store will know which are the right ones for your vehicle. I would only guess it would be around the same tq for them. Just remember a dab anti-seize on the plug threads and some de-electric grease on the tip connecting to the plug wire or coil plug.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Apr 2006
    Long Island
    Ditto, except buy OEM Motorcraft spark plugs. Also make sure to used compressed air to blow away any dirt, or sand so it does not make its way down into the cylinder.
    Feb 2006
    Rosemount, MN
    Already bought Motorcraft plugs. I'm going with the same torque as my Marauder, about 12 ft/lbs. I think the gap will be on an emissions sticker somewhere under the hood. We bought the Escape about a month ago with 104,000 on the clock. If they have never been changed, I hope the plugs come out without too much trouble. I think I'll remove one just to see what they look like. Thanks for the tips. Curt
    Apr 2006
    Long Island
    It couldn't hurt to spray some PB Blaster down into the spark plug holes before trying to remove them.
    Ford platinum plugs should come pre-gapped, I always thought that if you try to put a feeler gauger to measure the gap it would harm the platinum.
    OH YEAH!
    PB BLASTER!!!
    It makes Liquid Wrench look like water!
    Apr 2006
    Long Island
    OH YEAH!
    PB BLASTER!!!
    Yes it does!
    I love PB Blaster.
    300B
    Exhaust by Greg
    Jan 2008
    maryland
    Yes, I love it on rusted bolts.
    Feb 2006
    Rosemount, MN
    Plugs came out just fine. I think they were the original plugs. Had to remove the upper instake to get at the back 3 plugs.
  1. Spark Plug Easy Question
    By Mike M in forum Community Discussion
    Last Post: 02-23-2007, 02:13 AM
  2. Spark Plug shot out of head
    By wesman in forum Shop Talk
    Last Post: 11-01-2006, 09:48 AM
  3. SCT tune & spark plug help
    By Bill Lalk in forum Tuning
    Last Post: 10-08-2006, 04:24 PM
  4. Granatelli C.O.P. & Spark Plug Gap
    By Rider90 in forum Shop Talk
    Last Post: 05-16-2006, 09:43 PM
  5. Ford stock.
    By looking97233 in forum The Lounge
    Last Post: 03-15-2003, 11:23 PM
