Originally Posted by
Dragcity
Not if the frame was a sloppy mess.... THink about it. When torqued up, the engine wants to creep upward and to the right. Enough to lift the left tire off the ground. I dunno'. It might.
LOL....
I know that you can do this in a V8 Vega.
In fact, you can torque the Vega's frame so much that one front wheel is permanently off the ground!
