Results 1 to 15 of 17
Thread: DTC Code's P0351-P0358
    Feb 2005
    DC MD Area
    I know what they mean sort of but I been doing a little research and I have found it means a (possible ground fault a wire touching metal) on the circuit. Has anyone else here had this problem and what was the cause of it and what was the resolution.
    Here is what the codes are for.....
    P0351 Ignition Coil Primary A / Secondary Circuit Malfunction
    P0352 Ignition Coil Primary B / Secondary Circuit Malfunction
    P0353 Ignition Coil Primary C / Secondary Circuit Malfunction
    P0354 Ignition Coil Primary D / Secondary Circuit Malfunction
    P0355 Ignition Coil Primary E / Secondary Circuit Malfunction
    P0356 Ignition Coil Primary F / Secondary Circuit Malfunction
    P0357 Ignition Coil Primary G / Secondary Circuit Malfunction
    P0358 Ignition Coil Primary H / Secondary Circuit Malfunction
    2003 300A Black MM
    FRPP ALUMINATOR MOTOR 10:1
    STAINLESS WORKS LT HEADERS
    ADDCO FRONT & REAR SWAY BAR
    MONROE HD QUICK STRUTS FRONT
    QA1 ADJUSTABLE REAR SHOCKS
    Aug 2006
    Calgary,AB Canada
    You betcha.I get everyone of these codes everytime I pin it through the shift points.This started after the S/c install.I think it is a fault with the alt. but I am not having any drivability issues and it is not misiing,I know that for sure.I was wondering if anyone else had ever had this problem.What brought this on for you?
    4;10's,JLT RAI,and Lidio's sct live wire,new air freshner,.......and now #153 Trilogy..377 hp and 400 lbs
    Feb 2005
    DC MD Area
    Quote Originally Posted by chader View Post
    Happened 300 miles after my dyno tune. I have no drivability issues either read for codes a lil bit after clearing them then I got just 2 of them not all 8. Then one time all but 1. car doesnt miss and runs great. I have my Xcal2 hooked up to my laptop doing some data logging.
    Check out this http://dakotausa.com/vBulletin/showthread.php?t=17371
    2003 300A Black MM
    NorthEast Kingdom of VT
    maybe caused by low voltage when the alt cuts out at wot or sumpin
    Feb 2005
    DC MD Area
    Thats a possibility I guess but the tune is proven over on many vehicles....But I know some vehicles perform differently from others....
    2003 300A Black MM
    Feb 2005
    DC MD Area
    I read your thread on MCM and I think its just the fact when you nail it like I did I was going 120 or so. I have done just about everything in checking it out. I car didnt have a real aggressive tune prior now the tune is more aggressive and im using the smaller 3.2 pulley which im guessing when i spin it up more and really getting on it then I have the problem. Oh well the car is perfect and it so fun to drive its like going back in time fast lol...
    2003 300A Black MM
    Feb 2005
    DC MD Area
    Might be the gap of the plugs...Mine are at .030 originally they were at .032. Im going to re-gap them today and see what happens.
    2003 300A Black MM
    Aug 2006
    Calgary,AB Canada
    My codes started that way too.One at a time or only a few.But the harder I drove the more.In fact a couple of times I got a fuel pump circiut fault aswell.The one thing I have noticed is all coils and the fuel pump run off the same power supply,which comes directly from the alt.I did check plug gap already aswell.I agree it should not be a fault with the tune,because nobody else is having problems.I believe the alt. cut out is omitted whith Lidios tune.I have a couple of ideas of things to check when the roads clear up.1)if the alt is the cause(bad diode or some thing)if my battery is well charged and I unplug the alt.,take it for a run I maybe able to prove a fault with the alt.I have heard of this before.2)the one other thing I did at the same time the s/c'r was installed was replace the battery with a good used one.I have heard of batteries being at fault for stupid stuff like this?
    Let me know if you ever get any place with this.
    Chad
    Aug 2006
    Calgary,AB Canada
    just FYI,I changed my plugs to Motorcraft.AGSF-22C/sp-505.I have driven the ***** out of it.I got P0358 twice put never put the CEL on.I have since cleared the code and continued to drive the ***** out of it and no more codes of any sort.This thing is even more fun when no CEL is on.
    Feb 2005
    DC MD Area
    Cool man Im glad that helped you too. What kind of plugs did you have before you changed them and what were the gaps set at?
    2003 300A Black MM
    Aug 2006
    Calgary,AB Canada
    Quote Originally Posted by NATEHAWK View Post
    Champion....the gaps all looked good at .30.Thank-you very much for your help.I was starting to feel out on my own on this one,till I talked to you.
    Feb 2005
    DC MD Area
    Them damn chapion plugs..Boooo to champion Marauders like motorcraft.
    2003 300A Black MM
    Hawaiian Islands
    I was going to suggest looking at the gap and/or electrodes for "out of range" signs...
    What type of connectors are you guys using???
    With stock connectors, look for burning (dis-colored metal), I had two stockers that were burned and not conducting properly...
    With Granatelli's, look for arching (black marks), between the two ends of the clip...where the clip ends meet...Check, both top (coil side), and bottom (plug side)...
    Also look for torn plug boots...+ too much dailectic (spelling?) grease can cause it to ground...
    Mine (plugs) are set at .030...*NGK Tr6
    Good luck...
    ALOHA
    '03 A Build Date 8/02
    F.I.T. #6 ***RESURRECTED***
    *444 RWHP / 401 RWTQ
    *10 lbs. Boost
    *P1SC1 ProCharger
    Aug 2006
    Calgary,AB Canada
    [quote=Local Boy;614868]I was going to suggest looking at the gap and/or electrodes for "out of range" signs...
    Good luck...
    ALOHA[/quote
    got stock COP's and they had all looked good.I was told that if you had a COP problemyou would have actual missfire codes,but not to sure and don't want to know either.Alll is working good now.Thanx to everyone who tried to help us.
    Chad
    Feb 2005
    DC MD Area
    This problem is solved use motorcraft plugs and gap between 30 and 32.......
    2003 300A Black MM
  1. PCM Software codes demystified?
    Last Post: 01-27-2008, 09:50 AM
  2. Question about Calibration Codes
    By Breadfan in forum Shop Talk
    Last Post: 08-24-2007, 08:13 AM
  3. Xcal2 and how to read codes?
    By ctrlraven in forum Shop Talk
    Last Post: 01-09-2007, 10:29 AM
  4. Trouble Codes on my Cougar's comp
    By RR|Suki in forum The Lounge
    Last Post: 07-27-2006, 10:20 AM
  5. Trouble Codes??
    Last Post: 03-24-2006, 03:25 PM
