I've done this on my other vehicles.... Is it a benefit on our cars?
2003 300A BLACK - Flowmaster 40's w/ Rear Cat Delete - JLT Intake - Mo's Custom Tune - Steeda UDP 1"Drop/SBC/KYB- Addco Rear Sway Bar
Powerstop D/S Rotors/Ceramic Pads
Complete Interior/Cluster/Pod/Exterior LED Conversion
55w HID - Mach 1 Chin Spoiler - Blue Calipers/Valve Stem Caps - Front Plate Ditched/Holes Filled
Tow Hitch w/ Light Harness - OEM Rear Spoiler -Wiper Delete
79 Big Block Camaro - Rotisserie Resto
2015 Nissan Leaf - Tricked Out DD
74 Buick Lesabre Convertable
99 Camaro Z28 - 24k orig
I have one , but I don't believe it helps without a tune/power adder. Somone else will confirm of correct me
More importantly in a hot and humid state like Texas it would be ideal to maintain acceptable temps with the A/C running all the time.
STAY TUNED!!!!!!!!!!
160 degrees worked well for me, best when tuned for it. Still following this path with other Fords, like the 4.6L-3V, high HP and bone stock. If you change down, there are no consequences. When you do tune, you can add a little more timing and fuel, and that's a payback.
No because stock is 188, you want a 170 from Reische. Others will not have the correct thermal bypass unique to our motors.
See here: http://reischeperformance.com/#anchor
You can still get heat soaked and have the coolant get over 190, but this unit helps for sure. Moving along I get 175F all the time.
03 300A - Number 1727 - Super Touring - 10k in the best upgrades - 13.8@99 N/A - SOLD - STAP was so much fun, loved meeting you all and racing.
Great info guys...but 60 clams! ...is there .a Jet or Stant alternative?
Not that I'm aware of. These are quality hand modified and tested.
"Many have searched the internet and part stores for a properly fitting low temp thermostat for their late model GT500, Cobra, Mach 1, Bullitt, Mustang GT and Boss 302. Beware of aftermarket companies who sell the same thermostat for all Ford modular engines. Those units are designed for the 2V SOHC engine and, if installed in the improper housing, will be unable to shut off the bypass- allowing hot coolant to recirculate back into the engine at all times, reducing the efficiency of your cooling system."
Anyone have recommendations for how much timing to add and what to change fan settings to?
Whoops! Nevermind...
