Results 1 to 15 of 24
Thread: Got the sway bar installed
    Does it ever make a difference. Since I've got two of these things to play with, I can easily go back and forth between the stock one and the modded one for comparison. It corners much better, stays virtually flat in curves. I lubed the bushings the same way I did in the old days, just wrapped teflon tape around the bar before putting the bushings on. Lasts longer than grease and isn't as messy. I painted mine with black epoxy paint.
    Sometimes you add a mod and wonder if it really made a difference or was it worth the money. Not with this one. It's immediately apparent and well worth every penny.
    Mar 2003
    Los Angeles
    Re: Got the sway bar installed
    Thanks for the tip, FordNut! But I could've used that tip about a month ago! I've still got Marine grease on EVERYTHING! Anyway, I agree with you about the swaybar--the car really corners a lot better--congrats on your new swaybar! Are you gonna do the Eibachs too?
    No, I need the ground clearance. I drag things even at the stock height so I certainly wouldn't want to go much lower. Now if there were a truly progressive spring (the Eibachs aren't progressive after all) at the stock height or maybe 1/2" lower...
    Hiram, Georgia
    I hear ya! I did the Eibachs and the car will not clear my floor lift!
    May 2003
    Waterloo, IA
    < dreaming >
    I wonder if anyone's investigated swapping in air bags for the front springs to really lower the car "on demand".
    Without having looked under mine, I can probably guess the strut/shock on the front goes -through- the spring thus making this impossible.
    < /dreaming >
    I agree Fordnut!
    I finally had mine installed ... yup, big difference! It has the perfect amount of understeer for me.
    I had it powder coated with my valve covers
    Tom
    When (if?) I get my car back I'll be putting my sway bar on as well. Do you folks recommend painting the bar? Is there any reason to not just put it in place as it is?
    2007 Lincoln Town Car
    1993 Crown Victoria LX
    Fourth:
    I just installed mine right out of the box...it's anodised, and there were no indications from Addco that painting was necessary...I never even thought about it...
    Cool. I'll do the same, then. Thanks!
    Looks fine out of the box. I wanted to paint mine for 2 reasons. 1st, the OEM bar is painted black and 2nd it matches my powdercoated rear end cover/girdle.
    Las Vegas, NV
    Petrograde,
    Does not the sway bar bend? Is powder coat flexible? I would think it would break and flake off.
    2003 Marauder 1907 of 7838
    Built 06/24/02 Bought 10/25/02 Sold 1/5/19
    Reinhart chip,stat,plugs
    McGard locks
    Mercury logo valve/plate bolt caps
    Bob White black reflective letters
    Pioneer AVH-X2500BT
    Kicker 10" sub and 250 watt amp
    Gods Head spinners by Jerry
    hmm, ... I hadn't really though about it. I'm sure there is a little twisting. I'm sure it'll be ok. I'm more worried about road debris hitting it.
    Powder coating is fairly strong stuff from what I've seen. But, I'll keep an eye on it and post if it starts flaking off.
    BTW- sometime next year when I install some Eibach springs those will get powder coated too, if the sway bar holds up.
    Tom
    Long Island, NY
    Powder coating will not flake off. You can use it on springs swaybars and other movable parts.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    Thanks jgc .... that's what I thought.
    And...that 26mm, solid swaybar doesn't move like the stock, hollow, 21mm one did...
