Results 1 to 15 of 17
Thread: Marauder Specific Part Numbers
    Jun 2002
    Marauder Engine 3W3Z-6007-AA....$7312.00
    PCM 3U7Z-12A650-AMA
    Front Bumper Cover 3W3Z-17D957-AAA $919.99,
    must be painted to match (any color)
    Rear Bumper Cover 3W3Z-17K83-AAA $499.99,
    RH parking light 3W3Z-13200-BA $52.99,
    LH parking light 3W3Z-13201-BA $52.99,
    RH taillight 3W3Z-13404-BA $129.99,
    LH taillight 3W3Z-13405-BA $129.99,
    RH headlight 3W3Z-13008-BA $104.99,
    LH headlight 3W3Z-13008-BB $104.99,
    RR fascia 3W3Z-13A565-BA $239.99,
    TAILPIPES (these are complete from Muffler to Tip)
    RH 3W3Z-5230-BA $300.00 est. cost
    LH 3W3Z-5230-BB $300.00 est. cost
    GAUGECLUSTER W/ TACH 3W3Z-10849-EA $299.99
    OIL GAUGE 3W3Z-9G272-AA $83.99
    VOLT GAUGE 3W3Z-10AQ835-AA $79.99
    CONSOLE FOR OIL&VOLT 3W3D-5404810-A
    80MM MAF SENSOR 3W3Z-12B579-AA $99.99
    Dot Matrix dash trim pieces
    LEFT OF STEERING WHEEL 3W3Z-54046A63-EAA $51.99
    RIGHT OF STEERING WHEEL #?????
    3W3Z 3600-AAB steering wheel $ 209.99
    18"x8.5" wheel polished 3W3Z-1007-BA $537.10.
    Wheel Mercury head center cap 3W3Z 1130 AB ~$34.00
    Valve stem cap assembly 3W3Z-1700-AA $23.85
    18"x8.5" wheel unfinished 3W3Z-1007-EA $350.28
    18" mini spare 3W3Z-1007-DA $249.45
    GRILLE 3W3Z-8200-AAA $98.35 retail.
    FRONT COIL SPRINGS
    LH 3W1Z-5310-DA $43.99
    RH 3W1Z-5310-EA $43.99
    FOG LIGHT 3W3Z-15200-AA $49.99 EA.
    FOG LIGHT BRKT 3W3Z-15266-AA $5.49 EA.
    REAR BUMPER PAD 3W3Z-17C830-AA $17.99
    Marauder specific full carcover WeatherShield Black 2W3Z-19A412-CA $267.29
    Marauder specific cover Noah Grey 2W3Z-19A412-BA $238
    TORQUE CONVERTER 2W3Z-7902-AARM
    DRIVE SHAFT 3W3Z-4602-AA $248.82.
    AIR CLEANER Assembly. 3W3Z-9600-BA $144.99
    FRONT AND RR FLOOR MATS 3W3Z-5413300-AAB $.
    3W3Z-5413300-AAA. (Dark Charcoal) $92.80
    Tokico shocks
    Front ASH-83 $74.99
    Rear ASH-84 $56.99
    Rear Spoiler 2W7Z-5444210-AAB $250.00 est.
    2W7Z-5444210-AAA (primed)
    2W7Z-5444210-AAB (black painted)
    Trunk Organiser 2W7Z-54115A00-AA
    more trunk organisers:
    2W7Z-54115A00-BA (police) organiser 2 piece clear solid lid
    1W7Z-54115A00-AA (police)
    Real Autometer ProComp guages
    Oil 4327
    Volt 4391
    Exhaust tips without resonators
    "Megs" from Cone Engineering
    # C-15-04076-2 $60 a pair plus shipping.
    XW7Z-4602-AA MMC drive shaft
    F5UZ-7A039-A 11" tailshaft housing
    YW1Z-3F749-AA transmission and power steering oil cooler $95.00
    3W7Z-1007-CA 2003 Interceptor wheels
    Gas tank shield kit 3W7Z-9B007-AA(2003) LIST $105.32
    Police Interceptor rear springs (air susp replacement)
    F8AC-5560-HA L/R
    F8AC-5569-HA R/R
    Motorcraft replacement ww blades WW-2204 or XF6Z-17528-AA.$20.50
    Engine Blocks
    03 4v (Mach 1) 3L2Z 6010 AA $649
    03 Marauder 1L2Z 6010 BA $1583.60
    01 4V(Aluminu) 1L2Z 6010 BA $1583.60
    Remote fuel door parts
    Switch assembly F3LY9B242A
    Door Assembly 1W7Z54405A26BA
    Retainer for fuel door 1W7Z5428608AA
    Latch Assembly F3AZ5428610B
    Glovebox dampener
    F5AZ-5406102-AH
    LS/GS parts
    1W3Z-7D443-CA Chrome shifter bezel List $68.67 Disc $52.16
    3W3Z-54046A63-DAC Left trim with traction and adj pedals $63.65 Disc. $48.35
    3W3Z-54046A63-CAD Left trim without traction with adj pedals $63.65 Disc. $48.35
    3W3Z-54046A62-BAC Right trim 'LS' $108.75 Disc. $82.61
    3W3Z-54046A62-AAC Right trim 'GS' $108.75 Disc. $82.61
    Door panels
    3W3Z-5423942-DAC RF $496.08
    3W3Z-5423943-DAC LF $496.08
    3W3Z-5427406-AAC RR $666.07
    3W3Z-5427407-AAC LR $690.8
    prices shown are either retail or ballpark.
    Aftermarket mufflers
    RaVin Z55 (P/N 554201)
    Mar 2002
    Round Rock, TX
    Moved to the garage and stuck to the top as important info! Thanks RC!
    ONEBADMK8 Guest
    The driveshaft retail price is $248.82.
    The grill part # is 3W3Z-8200-AAA and is $98.35 retail.
    Robert J Bonann Guest
    Hey logan is that valve stem cap the one that has the gos head on them?
    Jun 2002
    Robert, from what I understand that part is for the chrome hex head cap. Also it is listed as an "assembly" which usually means it's more than one piece to that part under that number.
    There seems to be some controversy over the existence of a Gods head valve stem cap
    Member Number 32
    paurand Guest
    Question Brakes and suspension geometry
    Does anyone know if the Maruader uses standard Grand Marquis front and rear brakes? Also, is the suspension geometry (track, wheel offset, Etc.) the same as the other EN/FN vehicles? I know the springs, shocks, and wheels are different but those changes do not affect basic geometry.
    Appreciate any help or info that anyone can provide.
    Paul
    Oct 2002
    North Texas
    RC thanks for all the hard work on getting all those part numbers together for us!
    Do you think you could come up with a few more? Several of us are looking at replacing all the "dot matrix" stuff with the regular GM wood trim along with the chrome shifter bezel. Anything you can come up with would be great! TIA!
    Dean P. ~ Racerx88
    2004 Mercury Marauder 300A
    Silver Birch/Charcoal
    Dig Around in My Garage
    89lxbill Guest
    Forgot one
    You forgot one...
    The 4V engine...3w3z6007aa....$7312.0 0
    Chicagoland
    give you some prices on 2003 Marauder
    Repl Rt Muffler $402.90
    Repl Lt Muffler $402.90
    OUCH when it come time for new Mufflers!
    Repl Rear Bumper Cover $637.60
    Repl Rt Tail Light assy $156.05
    Repl Rt Door shell $1385.00
    Repl Rt/Rear Wheel 18" $344.00
    Repl Goodrich Gforce 245/55zr18 only $127.21. That's a low price for this tire! I check out other places and they where well above $200. Body shop got this from some place in Indiana.
    2003 Marauder 300A Owner
    Born 6/2/02
    Came home with me home 6/24/02
    [img]
    Jun 2002
    I think they may be hiking those prices a little. you can check prices at fordparts.com, oemfordparts.com, fordpartsnetwork.com
    Member Number 32
    San Diego California
    FORD part numbers for the tires are:
    9OO4-64168 235/50ZR18 G-force T/A $151.95 list $123.99 cost
    9OO4-40913 245/55ZR18 G-force T/A $156.95 list $127.99 cost
    If you find these tires at the 'cost price' you're doing pretty good
    Jefferson
    Pearson Ford
    San Diego
    "From the forest itself comes the handle for the axe"
    He's here! Carson James Mo--our 1st
    Born 6/02/2005
    Member Windy City Marauders
    1988 Mustang LX notch
    5.0 5 speed
    Engine by Total Performance
    GONE rear ended by a douchbag on his phone
    1990 Mustang LX Notch bought from the original owner
    2006 Dodge Magnum R/T (hers)
    (\__/)
    (='.'=) This is Bunny. Copy and paste Bunny
    (")_(")* into your signature to help her gain world domination.
    Mark McQuaide Guest
    Aren't these tires being advertised on tirerack.com for under $100?
    david spry Guest
    tire rack 888 371 8473
    $94 fronts
    $86 rears
    david spry
    This
    CONSOLE FOR OIL&VOLT 1W7Z-54044g02-AAC $42.00. (the suffix will change depending on color)
    is not the right part number it is acutally a small piece of carpet, trust me I ordered it!
    Jun 2002
    BigBadVic thanks, I'll fix that on the list. I wonder if that piece of carpet would fix the carpet gap situation on the right side of the hump under the dash?
