Results 1 to 4 of 4
Thread: Blower motor not running... help.
    Apr 2003
    Rock N' Roll Hell
    Angry Blower motor not running... help.
    My fan doesn't wanna work anymore that blows in the A/C. I took the fan off and had it hooked up to a battery and it worked. So the blower motor works, but I cannot get it to work from the A/C head unit.
    The hoses will still be wet and everything so the A/C is working, but the fan cannot seem to get a siginal or some sort to get working. I have checked the fuses and stuff and nothing is working.
    I am hoping it isn't the A/C head unit, but I bet it is. I had to replace it before and it was giving me similar problems, but not where the fan didn't function at all.
    What do you think it is?
    "Bye Bye, Johnny B. Goode."
    See my post here about this... Fix your BCM!
    Use the search function..... been discussed ad nauseum!
    Thank you...If I had suggested this I would be called a nasty internet bully.
    Though.....It is much easier to just dump another new thread on the website.
  1. Fan Blower Motor
    By Tamthemaam in forum Community Discussion
    Last Post: 04-23-2009, 12:12 PM
  2. need to test my a/c blower motor
    By baltimoremm in forum Shop Talk
    Last Post: 11-03-2008, 08:44 AM
  3. A/C Blower Motor Question
    By NOPDME in forum Shop Talk
    Last Post: 10-12-2007, 08:07 AM
  4. Help needed with A/C blower not running
    By Cuyax in forum Community Discussion
    Last Post: 07-28-2005, 10:11 AM
  5. Motor and blower for sale
    By Tom Doan in forum Community Discussion
    Last Post: 06-20-2005, 12:54 PM
