Trans, Windshield, Battery, Air Suspension, Dyno Check
95K Miles and 70+ 1/4 mile passes the trans started slipping. A-1 Performance Trans in GA rebuilt it. They inspected the PI 3,500 T/C and it's in good shape.
Windshield cracked from a rock impact. Safelite replaced it including the dot matrix pattern and an additional tint along the top.
The battery was not holding a charge. Replaced with a Red Top Optima
The air suspension would not hold air. Replaced the system with Suncore.
Injected Engineering Dyno Check - same as 5 years ago.
So far so good. Will know for sure when I take it to the drag strip in a few weeks.
