Results 1 to 15 of 22
Thread: Won't start after short drive (14 mi.)
    In Harms Way.
    So here the story,
    I go for a short drive them come home and park.
    When I go to restart the car it won't start (not even a click from the starter) just nothing.
    Fast flashing from the PATS light on the dash when key is turned to the on position but only sometimes.
    Been to the stealership 3 times (pockets now on empty) to have the keys, PATS transmitter, and PCM replaced with no satisfaction.
    Problem still exists.
    Problem has been ongoing for the past 5 or 6 weeks.
    Anyone else had this problem and if so what was your fix?
    Thanks in advance.
    4 doors - no waiting.
    2004 Mercury Marauder, BLACK w/Charcoal.
    Built 09/04/03
    #261 of 1236 Blacks, 3213 total for 2004
    (Thanks RoyLPita)
    Purchased 10/23/2003
    Adopted 04/25/2004
    Hot seats, 6 disc, trunk org, spoiler, avic f90bt & xm, ts-d802 speaks, bumper inserts, pedal and sill covers, 23% tint, 8000k hi/lo hid's & fogs, pro-guard, c.a.i., Xcal2, u.d. pulleys, emp pump, 180 t-stat, autolite 103 plugs, cop connects, coil covers, converter, aluminum pan & cooler, intake spacer, 4.10's, girdle, sway bars, control arms, head cooling kit, shorty headers w/ x pipe, dead pedal, budget big brakes.
    "Come with me if you want to live
    Oct 2005
    West 'burbs Chicago
    Have you tried starting it in Neutral for the heck of it?
    '21 F150 XLT 5.0 Sport
    '18 Chevy Malibu Redline
    '10 Harley Ultra Limited
    '08 Kawasaki ZX6R
    '03 Grand Marquis(sold)
    I'd ask dealer for money back since they threw a bunch of parts at it and didn't fix it
    Might verify if PCM is getting voltage
    Make sure all wires are good inside the fuse box under the hood, then check to see if you have a broken wire from fuse panel up to harness going into car below master cylinder
    Common for the harness to break around bumper area
    Check all the cables from the battery for clean, tight connections. Have you had the battery and starter tested? Most FLAPS will do it for you for free.
    Remove all the relays, circuit breakers and fuses from the battery junction box (under the hood and behind the battery). Clean the contacts of the relays and make sure your getting good contact in the junction box.
    Nov 2012
    Sacramento
    Do all above...
    Do you have headlights? Brake lights?? Just no start?
    Turn key and listen for a soft muffled "click." Have to listen hard.
    Had your issues, and it ended up being an $18.00 relay/fuse in same box mentioned above.
    I was "HOT" for three weeks about it until I calmed down and read and reread, and then did all of the suggestions in the response threads from guys above. When I get home I will look up the fuse/plug/switch for you.
    On plane now--searching is slow--but you can search my threads--I think FastBlackMerc above helped save me last time.
    Do all above...
    # 302 Starter relay - swap it with #304.
    I replaced ALL the relays in the junction box. There is a finite amount of times that they will work (cycle on & off). With the amount of miles on these cars I bet most of them are reaching the end of their life.
    If any one needs relays I can get them them for you for much less than $18.00 each.
    Nov 2012
    Sacramento
    Found it...
    From FastBlackMerc--who was my hero.... Here was my solution:
    First off, thank you all of you for assistance. I did do everything I could get to, and almost everything you suggested first thing this AM. I was on the road all week and flew home last night, so this was as fast as I could get to it.
    Great team giving great advice. Following-up, or as the great Paul Harvey used to say, "The RRRRest of the story!"
    I must be honest--this morning with sleep in my eyes and only on my second cup of coffee -- I cussed the car out, and told it (truthfully) that if it didnt want to start--it didn't really want me as its owner.
    I then switched out/exchanged the starter relay from 302 to 304 (thank you FastBleckMerc), and Bam(!) it started with ease on the first turn!
    I backed it out, let it warm up for 10 minutes, put Stabil in tank, drove and filled it with gas (never turned it off), drove it like a wildman for an hour, stopped at local Ford Dealer and bought a new relay (letting it idle the whole time), made an appointment to have the starter checked, and drove it back to storage driveway (again, letting it idle). I then tapped (maybe a little more forceful than a tap) on the Starter six or seven times, and pulled it back into the tight fit storage.
    Turned it off. Replaced /switched out relays again, pulled 304, put 302 back into 304, and the new relay in 302... And it started right up. The sound and tone of starter engaging was much "higher toned" and "lighter sounding" and "easier" than I ever recalled it being, so I started the cold dormant Silver sitting right next to it to compare--and they sounded the exactly the same."
    Try switching out relay between 302 and 304... First. Make sure they are clean as above.
    I also replaced the safety brake start relay behind the brake peddle, and my back still hurts (HAHAHA).
    In Harms Way.
    Quote Originally Posted by ChiTownMaraud3r View Post
    Yeah,
    first thing was to go to neutral to eliminate the neutral switch as a possible culprit.
    Built 09/04/03
    (Thanks RoyLPita)
    Adopted 04/25/2004
    In Harms Way.
    Thanks,
    I'll bring that to there attention.
    Built 09/04/03
    (Thanks RoyLPita)
    Adopted 04/25/2004
    In Harms Way.
    I'm supposed to take it back to the stealership Monday.
    I'll make sure to check those things over the weekend and test drive and see if it cures the problem.
    Thanks FBM.
    Built 09/04/03
    (Thanks RoyLPita)
    Adopted 04/25/2004
    If you have a tune, have your tuner disable PATS. Yes, it's that easy.
    In Harms Way.
    Do all above...
    I gonna tackle that fuse box.
    Thanks 1M.
    Built 09/04/03
    (Thanks RoyLPita)
    Adopted 04/25/2004
    In Harms Way.
    Car has 31,000 mi. on the but your fuse box theory fascinates me. and sounds simply enough to check.
    Gonna get right on it.
    Thanks again FBM.
    Built 09/04/03
    (Thanks RoyLPita)
    Adopted 04/25/2004
    In Harms Way.
    Found it...
    I'm on it.
    Thanks again 1M.
    Built 09/04/03
    (Thanks RoyLPita)
    Adopted 04/25/2004
    In Harms Way.
    I think I forgot to mention that it will start after sitting for anywhere from 10 to 45 mins.
    In the mean time gonna tackle the fuse box and circuit breaker then wiring check.
    Thanks to all.
    I'll be sure to post the results.
    Built 09/04/03
    (Thanks RoyLPita)
    Adopted 04/25/2004
  1. Do I have a short???
    By bugsyc in forum Interior Electrical/Electronics
    Last Post: 03-12-2016, 05:28 AM
  2. Short vid of 4.10's take off
    By SID210SA in forum Community Discussion
    Last Post: 07-11-2012, 06:16 AM
  3. Life is too short.
    By Tallboy in forum The Lounge
    Last Post: 08-12-2005, 09:26 AM
