Results 1 to 7 of 7
Thread: Squeaking brake pedal
    kdjlaw Guest
    I have a simple problem and I'd like to know if anyone's had the same one and how they fixed it. I have a fairly low-pitched squeak, almost a groan, coming from the brake pedal whenever I depress it. I've tried spraying WD-40 as high as I can go under the dash but it helps only a little. But the squeak definitely sounds like it's coming from inside the car. My girlfriend has exactly the same problem with her 2000 Lincoln LS. Thank you for your thoughts.
    Apr 2003
    5865 of 7839
    I have this - when the pedal is on its way back up, but that is since I had been messing with the plastic pieces under there - thought it might be rubbing up against one of them somewhere, but haven't actually been bothered enough by it to crawl under there and look.
    Self-importance is our greatest enemy. Think about it - what weakens us is feeling offended by the deeds and misdeeds of our fellowmen. Our self-importance requires that we spend most of our lives offended by someone. -- Carlos Castaneda
    Oct 2003
    Beaufort, SC
    All of my CV's did this and so far the Marauder has not!!
    It is the dust boot on the rod going throught the firewall to the brake booster!! You can either replace the booster or cut the boot off (what the dealer did on my '98 CV) to stop it??
    I tried squirting some lube into the boot with a Hypodermic needle with limited success!!
    This is very common AND ANNOYING with Ford products!!
    Marauderjack
    kdjlaw Guest
    Thanks, Marauderjack. I have to replace the booster because the boot is part of the booster and not a separate part? If so, I'm liable to take a knife to the boot this weekend.
    Jan 2006
    Port St. Lucie
    I had a similar problem and the dealer replaced the master cylinder and the noise disappeared.
    2003 300A
    black
    XCAL2 (DENNIS REINHARDT)
    blue inserts
    GODSHEAD oil cap (COLEX)
    GODSHEAD badging(CARMOTORSPORTS)
    flowmaster super 40s
    silverstars
    BADGELESS GRILLE(2ND OWNER)
    DRILLED/SLOTTED ROTORS
    NAPA CERAMIC PADS
    PROGUARD(DENNIS REINHARDT)
    ADDCO FRONT AND REAR SWAYS(DENNIS REINHARDT)
    MACH 1 CHIN SPOILER(INNNOVATIVE INTERCEPTORS)
    Aug 2005
    TAMPA BAY & SNOW BIRD MAINEIAC
    Is your girl friend in both cars when you hear the groan?
    GOD bless my friends, Paula, Cheese(Rex) and Alex and all those still with us.
    Semper Fi
    SUPPORT THE WOUNDED WARRIOR FUND
    2012 HTRDR Lincoln MKT AWD Twin Turbo SHO Eco boost MOTOR
    04 DTR "FruitPunch"5/17/04 Living with the "LEMONADE" in Ed's garage...
    TRILOGY EATON #110 11-25-05
    TRILOGY Twin Screw #003 Thank you MCM & JERRY BARNES
    Install by THE STOOGES
    ASS TUNE by LIDIO
    "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery"
    --Winston Churchill
    Feb 2005
    Clermont Florida
    Same problem here too. I'm taking my car in hopefully saturday for a tranny flush and I was going to have the dealer look at it then.
    Performance
    Dress
    LOC: Clermont Florida
  1. Brake Pedal Vibration at idle.
    By Marauderoz in forum Shop Talk
    Last Post: 03-04-2006, 09:26 AM
  2. Petals coming in tomorrow anything I need to know?
    Last Post: 08-25-2005, 05:26 PM
  3. TCE brake kits REVISTED
    By Todd TCE in forum TCE Performance
    Last Post: 02-13-2005, 12:18 PM
  4. A Knocking in my brake pedal
    By MarauderMark in forum Shop Talk
    Last Post: 10-09-2004, 06:55 PM
  5. Marauder Polished Pedals Update
    By Ladyhawke in forum Shop Talk
    Last Post: 04-16-2004, 04:40 PM
