Results 1 to 15 of 16
Thread: Permanent fix for heated seat light
    Well my passenger side heated seat light started to flicker at 24k miles.
    The drivers side switch gets much more use then the passenger side.
    What is the issue with this damn switch???!!! How hard can it be to get a simple switch to work?! LED life is measured in thousands of hours...not minutes.
    Has anyone done some forensics on the failed switches? I worry that this will revisit me at 48k miles except it will be on my dime!
    Mischief Managed!
    Retired to weekend trips.
    105k miles.
    04MM Fully Loaded.
    Trillogy Stage II
    Metco RCA
    Baer Big A$$ Brakes
    GT40 Fuel Pump
    Lowered Suspension
    Apr 2003
    5865 of 7839
    My passenger side seat light went out long ago, and it ain't worth my deductible, either.
    Self-importance is our greatest enemy. Think about it - what weakens us is feeling offended by the deeds and misdeeds of our fellowmen. Our self-importance requires that we spend most of our lives offended by someone. -- Carlos Castaneda
    Quote Originally Posted by Badger
    Well my passenger side heated seat light started to flicker at 24k miles.!
    My driver's side seat light has been flickering for the past 5,000 miles (started at 30K). I try not to look at it.
    Mine flickered for 25k miles before I did anything about it.
    Oct 2003
    Beaufort, SC
    My window switch light was intermittant and flickered and I guess it was a bad connection....not the LED per se?? Dealer ordered the whole switch module for me and I changed it in the parking lot and he covered it under warranty!!
    If I remember the whole module wasn't but $35.00 or so....How much could the heated seat switch be?? I don't have them and don't know what it looks like??
    Marauderjack
    Apr 2005
    Queens NY
    the Driver side window switch, the light for the "up window" is out.
    Is there anyway to repair this without having to replace the entire switch??
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    Oct 2003
    Beaufort, SC
    Sorry but no....the whole window switch module has to be replaced.
    Marauderjack
    Off-Shore America
    Sorry but no....the whole window switch module has to be replaced. Marauderjack
    And it's quite easy, a simple D.I.Y. I replaced two, one for no illumination on the #3 MM, the other for intermittent "up" failure on the "#1x" MM.
    I've got the flashing driver's side heated seat switch on #3 too. Can anyone confirm what the repair is? If it's just another switch module, I can do that. Just don't know if this is all it is. Anyone?
    Derby City, KY
    Mac,
    Mine was replaced under warranty, and was fairly simple as the door panel had to be removed, and the switch replaced.
    I was told by my L/M Dealer that this is common on the MM's as well as the GM's.
    Total job was about 30 minutes as I watched the tech do the R&R.
    Mike.
    Quebec city Canada
    Passenger heated seat switch replaced twice under warranty in the last 4 months and once on the driver side. They seems to be crap design of some sort. It is not possible to just replace the light. Creative engeneering ?
    The light is embedded in a big square plastic module with 10 -20 wires sticking out.
    My warranty is almost out and i don't know what to do about it. Maybe look for a 1963 Marauder. In those times .....
    Quote Originally Posted by Blackened300a
    mine is out also...
    BAD DTR MERK 04
    What a crappy design. Wonder what actually goes on these suckers. If it's a simple loose connection it would be worth while for FORD to fix it. I mean it must be costing them $1000's with all of the warrantee work.
    Mischief Managed!
    105k miles.
    04MM Fully Loaded.
    Trillogy Stage II
    Metco RCA
    Baer Big A$$ Brakes
    GT40 Fuel Pump
    Lowered Suspension
    Jun 2005
    East Lansing, MI
    Quote Originally Posted by michael ward
    mine is out also...
    ummm there is no up light on the drivers side window button...
    11.90 @ 117.5mph on 93 octane
    Igziabeher
    Off-Shore America
    For you guys with no light in the window switch, it's a one piece modular switch with a plug-in install. here's a pic from my Gallery...
    http://www.mercurymarauder.net/showc...c=3&userid=392
    Sealed unit for all the window switches, nothing to maintain or repair, just replace the module. I've replaced two now.
    Carefully (it's plastic) pop off the switch panel and the module will come out. Again, carefully pop out the module from the wire harness and replace it, and restore the panel to the door. 10 minutes...
    P/N is 5L1Z-144529-AA. Retail is 49.23, you can do better if you're a favorite with a parts department somewhere. My local cost is 33 bucks from my dealership.
    Now...Can anyone tell me that my flashing heated seat switch is likewise a bad module? It's the backlit illumination that's flashing, not the on/off indicator. Thanks!
    I believe they can be found on ebay for about $20
  1. How many forum users does it take to change a light bulb?
    By 2003Marauder in forum The Lounge
    Last Post: 03-30-2007, 11:32 PM
  2. Clev. Meet Beer/pop List
    By CRUZTAKER in forum Events
    Last Post: 06-08-2006, 08:02 AM
  3. Replacing a Light bulb...
    By Logan in forum The Lounge
    Last Post: 03-18-2005, 08:05 AM
  4. Marauder Has Good Showing @Drag Strip
    By sailsmen in forum Community Discussion
    Last Post: 10-04-2004, 05:05 AM
  5. Car Seat Question....
    By Petrograde in forum The Lounge
    Last Post: 07-11-2004, 10:02 PM
