Results 1 to 4 of 4
Thread: World's fastest car on pump gas
    Aug 2004
    Kansas City
    THE POSSIBILITIES!
    Built with help from Super Chevy Magazine to demonstrate the potential of a carbureted, centrifugally blown engine using 91 Octane pump gas and off the shelf parts, this 3,300 lb. car has far exceeded expectations, evolving into an extreme example. This particular 427 ci combination is the product of lb/ci rules observed in heads up racing. When rules aren’t a factor, this level of power is more commonly produced using a 502 based engine, often times using higher octane fuels. This engine makes well over 3 hp/ci with an Air to Water intercooled F-2 ProCharger breathing 28 psi of boost through a pair of lightly modified 450 Holley carbs. Extreme ProCharged applications running racing fuel are currently making in excess of 5 hp/ci, propelling cars to speeds well in excess of 210 mph. ATI does not recommend duplicating this Nova’s particular combination, as there are easier ways to achieve these same power levels. Please contact our technical service staff to determine a combination that best meets the needs of your particular application.
    1969 Super Chevy Nova, Config. 1
    427 cid, Production Block and Crankshaft
    GMPP Rect. Port Heads, Solid Roller Cam, 7800 RPM
    Single Carburetor, 91 Octane, 3400 lbs
    F-2 ProCharger, Serpentine Drive, 3 Core Race Intercooler
    24 psi, 1275 HP, 158% HP Gain
    3 HP/ci on Pump Gas
    1969 Super Chevy Nova, Config. 2
    2 450 Holley Carburetors, 91 Octane, 3400 lbs
    F-2 ProCharger, Cog Drive, 1800 hp A/W
    28 psi, 1495 HP, 203% HP Gain
    3.5 HP/ci on Pump Gas
    Results from November 2003
    Super Chevy Show at Las Vegas
    Home of the FIT/Procharger Racing Team
    There Ain't no Kool Aid or Stooges here!
    Orlando, FL
    ...Gotta love that, even if it is a Chevy.
    I love the Y piece and the twin polished 'bonnets' on the carbs!
    I wonder how that S/C set up would look on a 2 x 4 bbl Cobra....
    Orlando, FL
    Yeah, I'm thinkin how a tri-polished peice would look on the 3x2 I have.
  1. Fellow Owners, check your car!
    By Jim in forum Community Discussion
    Last Post: 02-26-2011, 12:54 PM
  2. South East Regional Fall Meet
    By MM03MOK in forum Community Discussion
    Last Post: 07-09-2005, 12:52 PM
  3. Forbes.com Review
    By 213Cobra in forum Community Discussion
    Last Post: 11-27-2002, 07:25 PM
  4. Fastest and quickest Marauder powered race car
    By Accufab Racing in forum Community Discussion
    Last Post: 10-04-2002, 10:17 PM
