Results 1 to 6 of 6
Thread: Tig welding advice needed
    Feb 2005
    Clermont Florida
    If there are any welders here I could use some advice on my tig. I bought an Everlast Inverter AC/DC tig. I would like to weld aluminum but I can't figure out what electrodes to use. The aluminum is about 0.030" thick. Can I use Thoriated Tungsten with a point with an inverter to weld aluminum? I just don't know.
    Performance
    Dress
    LOC: Clermont Florida
    Feb 2010
    Cincinnati, Ohio
    My brother recently bought one of these welders. From what I remember he said that he uses the thoriated tungsten, but I not sure.
    Try this page http://www.weldingtipsandtricks.com/...-aluminum.html it has some good info on it. I will try and get with my brother tomorrow and see what he says. I hope this helps.
    Ask CBT. He might be able to provide some help.
    Smithfield, Virginia
    Do NOT weld aluminum with a pointy tungsten rod, you want a small ball on the end of it. Easy peasy.
    WIN WIN!~ Zack
    Sep 2008
    LOVES PARK IL
    Welding aluminum is fun once you figure out how to do it.
    Tungsten, ball end, argon, keep the tip as close to your work as possible and watch your heat. I'd rather weld aluminum than anything else.
    Feb 2005
    Clermont Florida
    Looks like I'll need to order some tungsten rods to then. Thanks
    Performance
    Dress
  1. Used Car Advice Needed: Lincoln LS 8
    By rayjay in forum The Lounge
    Last Post: 01-07-2010, 10:13 PM
  2. O2 sensor advice needed
    By CRUZTAKER in forum Shop Talk
    Last Post: 07-27-2008, 07:58 AM
  3. 5.0 CARB to EFI Advice needed...
    By High-C in forum Shop Talk
    Last Post: 07-23-2008, 03:32 PM
  4. Guitar advice needed
    By not5-0 in forum The Lounge
    Last Post: 05-05-2008, 07:26 AM
  5. Info & Advice needed.
    By PhastPhil in forum The Lounge
    Last Post: 08-08-2007, 07:31 AM
