Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: Oil pan baffles
    Jan 2006
    Northern California
    Oil pan baffles
    I know the function of oil pan baffles. What I do not know is how critical their are for street use. I plan on driving hard in corners, but I have no plans to do any flat, drag or race track type driving.
    So, are oil pan baffles mandatory or a nice-to-have?
    Jan 2006
    Northern California
    Anybody home?
    Blog Entries
    2
    I remember a brief discussion about 10 years ago.
    If you do a search I don't think you will find much on it.
    I know a few members have auto crossed w/o reporting any issues.
    Do you have a list of all your proposed performance mods to put it into perspective?
    Jan 2006
    Northern California
    Agreed, as I searched and found very little.
    Build Project:
    http://www.mercurymarauder.net/forum...ad.php?t=58600
    Nov 2012
    Sacramento
    When can we see your ride?...
    Jan 2006
    Northern California
    I think you are jinx'ing me. Every time you ask, the delivery date is delayed.
    I am going with "who the f*** knows!
    I didn't do anything with baffles per se, but I did put in a windage tray. And aftermarket oil pan. I had to modify the sump to clear something, I believe it was the passenger side header. The pan may have had integral baffles, I can't recall after all these years.
    Edit: the pan did have integral baffles http://www.mercurymarauder.net/forum...4&postcount=27
    Jan 2006
    Northern California
    It appears most high performance cars have a windage tray and slosh baffles.
    Ford GT350
    Nissan GTR
    Corvette C7
    Dodge Hellcat
    The engine uses a new oil pan with extra baffles and windage tray to keep the oil where needed under hard acceleration.
    Blog Entries
    2
    "........ I plan on driving hard in corners, but I have no plans to do any flat, drag or race track type driving....".
    I am not familiar with your engine build enough to know what was changed as respects the oil pan or pick up.
    Based on what I see you don't need anymore than what the stock MM has.
    Jan 2006
    Northern California
    Thank you.
    (to note build parameters)
    Jan 2006
    Northern California
    I have a Canton performance oil pan (forget the model #). Apparently I only have a windage tray - no baffles, crank scraper or recovery pouch.
    https://www.cantonracingproducts.com...e_Secrets.html
    http://www.enginelabs.com/news/canto...mance-secrets/
    Jul 2011
    Bay Area, CA
    Quote Originally Posted by Lowndex View Post
    Talk to lifespeed about this, I remember him posting about it not too long ago.
    Just remember if youre swinging donuts, hit a figure 8 every now and then so you can be sure the oil pump isnt sucking dry
    98 P71 SOLD
    Jan 2006
    Northern California
    Lifespeed has baffles in his oil pan.
    Chicago
    Steven
    2004 Marauder Black, loaded
    Vortec S/C
    4.10s
    3500 PI Stall
    Kook's headers
    476.9 rwhp 385 lbs/tq
    Lidio tune
    2004 Suburban Dark Charcoal
    Quote Originally Posted by stevengerard View Post
    I seem to recall somebody trying it long ago and it hit the crossmember. Maybe the design has changed since then.
  1. This isn't how I do it! - Oil Change Women vs Men
    By Breadfan in forum The Lounge
    Last Post: 07-21-2006, 11:49 AM
  2. Oil change:
    By magindat in forum The Lounge
    Last Post: 04-18-2006, 11:12 AM
  3. Oil Change instructions
    By TripleTransAm in forum The Lounge
    Last Post: 01-04-2004, 04:17 PM
  4. Mobil 1 - OK?
