Results 1 to 3 of 3
Thread: Replacement Conical Filter for Pro-M
    Found it at FFW in Bristol. Made by UPR. Instead of the chrome end cap, it has an inverted-cone of additional air filter material. I have noticed the heat retention in the original chrome one and thought it would be nice to have the type with extra inlet surface area but didn't think one with the 3-stud mounting was available. Surprise!
    MikesMerc Guest
    Thanks for the tip
    Nice call on the filter swap, Brian. Especially, with the inlet for the air behind the headlamp, into your airbox being right on the tip of the filter.
    In Metco's final version of their cold air kit, they will provide the S&B filters with it, which was the first company to contruct their filters this way, utilizing the end of the "cone".
  1. (Stock) Fuel Filter Replacement
    Last Post: 01-01-2005, 06:11 PM
  2. Conical Filter, Road Spray, Fenderwell Liner
    By FordNut in forum Shop Talk
    Last Post: 07-18-2004, 09:50 PM
  3. Interesting air filter info
    By RF Overlord in forum Shop Talk
    Last Post: 01-29-2004, 08:46 PM
  4. Oil Filter Changing/Spark Plug Replacement
    By 427435 in forum Community Discussion
    Last Post: 10-14-2002, 09:12 AM
  5. Oil change: that pesky filter
    Last Post: 08-11-2002, 05:28 PM
