Page 5 of 5 FirstFirst 12345
Results 61 to 74 of 74
Thread: Anyone running 1 15" sub?
  1. #61
    Apr 2010
    South Florida
    (1) Kicker 15" L7 (2008)
    (1) Kicker ZX1500.1 Amp (2008)
    (0) Issues.
    #1618 of 3214
  2. #62
    Aug 2010
    Gadsden, Al
    Nice setups guys. I just want my trunk space back, and be able to use my trunk storage
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  3. #63
    Dec 2015
    Remington, IN
    I ended up keeping my trunk space. I used an old enclosure from a previous system I modified for the new 12" JL Audio sub. (old sub had a trashed surround) Took the factory sub out, and it's mounting bracket. The box fit right in. I welded bolts onto the floor and bolted it down.
    Bolts welded on floor
    Sub box on garage floor
    Sub face
    Bolted down
    Finished install
    2003 Marauder... the gentleman's hot rod.
    You know what I like best about most people? Their dogs.
  4. #64
    Aug 2010
    Gadsden, Al
    How does it sound? Install looks clean. I like it. Where's the amp?
  5. #65
    Dec 2015
    Remington, IN
    Sounds wonderful. Took a while to get it all adjusted to my taste. The head unit controls were kinda overwhelming to an old fart who doesn't like reading instructions.
    The silver thing with the wires coming out of it on top of the sub enclosure is the little JL Audio XD700/5v2 5-channel amp that runs the system. Speakers are also JL Audio. Fronts are the Evolution C3 5.25" Component Speakers, and the rears are the 5x7 versions of the same.
  6. #66
    Aug 2010
    Gadsden, Al
    Nice!! I removed the 15" house Speaker of course, but I decided to try some things with my 10's. I left the amp in bridge mode and bridged the 2 10's and WOW! I've had these subs for years and didn't know they could hit like that.
  7. #67
    Dec 2008
    South Carolina
    Thanks daddy that's what imado. Clean and simple
    Adopted 3/31/11. Sold
    03 300a black #1199
    TERMINATOR SWAP
    430rwhp. Done by mo's
  8. #68
    Feb 2011
    New Jersey
    Quote Originally Posted by BAD MERC View Post
    It's all JL Audio and Eclipse. There's a backup camera in the keyhole, DVD/Nav/iPod. The floor conceals the spare tire. it's lighted with LED's that are RGB for any and all color combinations.
    This is out standing. Excellent set up man and looks real nice. I love that set up and still have plenty of trunk space left.
  9. #69
    Dec 2015
    Remington, IN
    Quote Originally Posted by JBeezy View Post
    Depends on if you wire two subs in series or parallel, as the resistance changes dramatically. Also make sure your amp is rated for the resistance load you end up with. If you run a 2 ohm load and your amp isn't rated for it, it will overheat and be damaged. My 12W3v3-2 is a 2 ohm sub that can handle 500 watts RMS, but it matches up real well with my amp that is 2 ohm rated, and can safely put out 300 watts at 2 ohm on the sub channel. I chose the speakers sub and amp I have because how well they match up with each other on the spech sheets, and I got a pretty damn good sound out of it.
  10. #70
    Aug 2010
    Gadsden, Al
    Quote Originally Posted by daddyusmaximus View Post
    My subs are Kenwood kfc-xw1100dvc and they are wired as shown below in Figure 5.
    Here are the specs for them
    I have them bridged and my amp is a Fosgate T5002 and here are the specs
  11. #71
    Dec 2015
    Remington, IN
    Should sound nice. What do you have for front and rear stage?
  12. #72
    Aug 2010
    Gadsden, Al
    JL door and rear speakers on a JL 4 channel amp. I had 6x9's put in the rear as well. It does sound good, well better now. I would still like to have 1 15" I could install when we take trips and need the space
  13. #73
    Dec 2015
    Remington, IN
    A single 12 can fit where the factory sub was... I love mine.
    Sent from my SM-N910V using Tapatalk
  14. #74
    Feb 2011
    New Jersey
    Quote Originally Posted by 8UWITH6 View Post
    Two 8's under the rear deck ported (port is inside the enclosure now). Soon to be 3 or 4 and ported into the rear deck.
    How do you support the wood to the quarter panel where the amps are mounted?
  1. Replies: 21
    Last Post: 02-22-2014, 08:52 AM
  2. "Special" MV11 Southern Mercury Marauders "BreakfastClub"
    By Marauder_Santa in forum Marauderville 11 Updates
    Last Post: 09-25-2013, 06:04 AM
  3. Ford's "Brand DNA" team and "Way Forward" plan
    By GreekGod in forum The Lounge
    Last Post: 04-25-2007, 06:34 AM
  4. Replies: 3
    Last Post: 04-06-2003, 08:08 PM
