Results 1 to 15 of 19
Thread: Oil pressure gauge swap
    Jul 2015
    Livermore, Ca.
    Well that was tedious... Wish me luck!
    Jul 2011
    Kentucky
    did mine a few weeks ago , love the result of a working guage
    2003 Marauder 300B 148K 1 of 364 Heated Seats
    2003 Mach 1 5spd Torch red 29K
    Pa
    Well that was a great read.
    If it's cheap and reliable it isn't fast
    If it's cheap and fast it isn't reliable
    If it's fast and reliable it isn't cheap
    Install green LED bulbs so you don't make that burned spot any bigger.
    Quote Originally Posted by blkZooM View Post
    The how-to is posted elsewhere.
    Pa
    I know that but I thought I was going to read more than that at least.
    Jul 2015
    Livermore, Ca.
    Jim, can you please pm the p/n LED you would use?
    Oct 2005
    Southwest Florida, Lee County
    I just did mine, too! the swap was extremely simple but the difference visually is almost indistinguishable UNTIL you turn the lights on. I did the face swap, too and although it was tedious it only requires patience and common sense.
    2004 Mercury Marauder
    2,187 of 3,214
    997 in Silver Birch
    448 with light flint interior
    304 with heated seats
    336 with sunroof
    I don’t get it, sorry. Face swap for what? I followed Wes Chain’s how to 12 years ago or so and got a working real OP gauge without changing anything.
    I would be interested in LED’s for my 3 gauges; I think the colored sleeve I had on the tranny temp gauge off gassed and slightly fogged the lens I wrote about. That bulb is on as long as the car is and gets very hot.
    FYI, I moved the cigarette lighter to the side, and have OP, Voltage and tranny temp in a row, with green, white and red lighting. Looks good, and not too bright.
    Quote Originally Posted by Svashtar View Post
    The face swap is swapping the face from the OEM gauge with the face of real gauge so the gauges look the same. You also need to change out the sending unit.
    IMHO.... it is easier to change both gauges as most people will not know the difference.
    PM me for info on the LEDs.
    Thanks, I think I’m getting senile here. I did buy a new OP gauge and added the trans temp gauge, but left the Volts gauge stock.
    That seemed to get everything matched up, so not quite sure why you would change both gauges?
    As for the sending unit, IIRC I just followed the instructions Wes from Innovative Interceptors posted here back then, and rewired the connection under the car and everything worked fine.
    Here’s an attached pic of the 3 gauges, with the middle one stock:
    I appreciate the info on the LEDs and will PM. I guess it doesn’t hurt to have the trans temp light always on, but it does get hot.
    Sounds like you hooked up a keyed 12v power wire to the lighting wire on the gauge.
    As for the reasoning on swapping the volt gauge, isn’t there a difference in one being only backlit (stock) and the replacement having the numbers and lines lit as well? It’s been awhile since I seen a stock gauge.
    The stock gauge is back-lit through the numbers and the primary indicator lines. The replacements are perimeter-lit with a solid (opaque) face.
    Norm, except for the tiny bit of black rubber glommed onto your trans temp gauge, your gauge pod looks identical to mine.
    Oct 2005
    This is what the swapped gauge looked like at night BEFORE the face swap. Essentially the only thing swapped was the internals and the sending unit. What the eyes now see is OE equipment on the surface.
    2,187 of 3,214
    997 in Silver Birch
    336 with sunroof
    Quote Originally Posted by BAD MERC View Post
    Ok, thanks. Like I said, I’m getting senile. Now I recall, I installed the real OP from DR, and as soon as I saw they didn’t match picked up a matching Volts from online.
    Your setup looks good, thanks for confirming!
  1. Oil Pressure Gauge
    By Fly007 in forum Shop Talk
    Last Post: 03-13-2016, 08:43 AM
  2. Wanted To Buy Real AutoMeter oil pressure gauge with OEM face swap
    By Anthony84 in forum Marauder Parts/Misc. Wanted
    Last Post: 08-15-2015, 04:03 AM
  3. Oil pressure gauge
    By blkZooM in forum Shop Talk
    Last Post: 02-19-2015, 12:54 PM
  4. New Oil Pressure gauge in...
    By RacerX in forum Shop Talk
    Last Post: 08-20-2009, 05:28 PM
  5. Fuel Pressure Gauge? A/F Ratio Gauge?
    By Rider90 in forum Shop Talk
    Last Post: 02-07-2006, 07:42 PM
