I need to know where to start...ass dropping it low TERRIBLE!
Help!
Help!
"Murcy"
135 of 11,052
check ride height sensor is attached on watts link driver side in front of and above axle
Blown fuse, locked up compressor, cut wire, what he said ------^
Do you hear any noise at all key ON drivers door shut?
I took mine to the dealer years ago and they changed everything; both bags, compressor, fuse. I never did find what was the actual failed part.
Google; Troubleshooting mercury air ride suspension.
RAS help here
more than likely it's the air pump.
http://www.suncoreindustries.com/sus...ompressors.php
Those were the days.........
DANG THEY'RE CUTE!!!!!!
Smile and Nod
I love THIS bar
Follow the air tubing from the compressor to the rear end. We had a brand new CV that must have been a Friday 4:55 car and STAP didn't "click" the tubing in securely. It popped loose after a few thousand miles leaving the ass of the car on the bump stops. Easy fix if that's what happened to your car.
The pump comes on... The rear is new so... It could just be the pump
"Murcy"
135 of 11,052
If the pump makes noise, let's hope it puts out air
Pull the air filter, check to see if the line is connected to the compressor, if that's good, check to see if it's connected out back
I would say the pump would run all the time until the height sensor closed
Does your air compressor shut off like normal?
This recently happened to me...again. I checked all the usual suspects but it ended up being the air compressor...again. While waiting for a new compressor, I filled the air bags and turned the air suspension switch in trunk to "OFF" position. You can fill bags easily with a compressor by using a fitting that matches the air tube running to your air bags. This way you won't be dragging around in the meantime.
2004 Marauder
SVT Contour 3L
