Results 1 to 15 of 16
Thread: Oh, No! Transmission Line Leak?
    Houston, Republic of Texas
    The garage floor has been totally dry, no signs of drips, leaks, etc. Until now.
    Tonight I let Dawn use the MM to drive to a meeting at church, since her car is in the shop. After she left, I notice red fluid on the floor, not under the tranny, but under the area where the hood is when the car is parked. It wasn't in a little puddle, but kind of "sprayed" around. Could a tranny cooler line or something like that have sprung a leak, or maybe some connection come loose? If it did that up front, the fan could have sprayed the fluid around.
    I'll have to look at it later tonight when she gets home.
    Any suggestions?
    2003 MM 300A
    Born June 18, 2002
    Adopted Christmas Eve, 2002
    First Factory Rebuilt Ford P.O.S. Engine at 81,000 miles
    Second Factory Rebuilt Ford P.O.S. Engine at 101,000 miles
    Ford Racing 4.10's
    Reinhart/XCal2 Custom Tune
    Reinhart Underdrive Pulleys
    K&N Conical Air Filter
    Reinhart Exhaust with 18" Magnaflows
    Silencer Removed
    Bosch Micro Edge Excel Wiper Blades
    Bob White Red Bumper Inserts
    Lone Star Beer in cup holder
    Fellowship of Christian Cowboys
    license plate bracket
    God and the soldier we adore, In times of danger, not before.
    The danger gone, the trouble righted, God's forgotten, the soldier slighted.
    Cynicism is the smoke rising from the ashes of burned out dreams.
    Quote Originally Posted by Ross
    Any suggestions?
    Maybe power steering fluid?
    03 MM 300B Silver (Mostly stock, wife's car, 300k mi) FPG # 7053 of 7838 or 49 of 417 SB
    03 MM 300B Silver, Stock, 50k mi FPG # 7134 of 7838 or 89 of 417 SB
    01 F150
    00 F150 4x4
    Could be PS fluid. I hope it's in an obvious enough place that I can find it easily later tonight.
    2003 MM 300A
    Born June 18, 2002
    Ford Racing 4.10's
    Silencer Removed
    You know Ross, how ironic....
    I crawled under the front tonight to do an oil change and discovered what we in the military call a CLASS I leak coming from somewhere. It's not red though.
    The front swaybar from the middle to the driver's side link was covered in oil residue. There was also a small amount of residue on the crank pully.
    Very odd. Hope you find your leak....hope I find mine as well, cause I cannot figure where it could be coming from.
    2017 Niro
    Washington DC
    Rear Trany seal has been my issue for the last couple of years. I had two of them replaced under warrenty.
    Quote Originally Posted by merc
    How about sending it in under warrenty???
    Panther II Guest
    Check around the PS resvoir and see if the line connections are secure, also make sure the PS fluid level is good. If they are, then a check in with the local L/M dealer should net you a warranty replace. It sounds like this might be PS problem considering PS fluid has a red fluid appearence.
    It's PS. Reservoir is low, and it looks like it's leaking from a fitting that comes out the bottom rear of the PS pump. Should hopefully only take a little tightening to fix (hopefully). Naturally, it's in a place where I can't possibly get a wrench on it. Guess I'll head to the dealer in the morning. Of course, my warranty expired a few days ago. Guess we'll see how the new extended warranty deals with me.
    2003 MM 300A
    Born June 18, 2002
    Ford Racing 4.10's
    Silencer Removed
    Just had my PS line from the pump to the rack replaced under warranty.
    The techs said panther cars are notorious for that hose leaking.
    Nov 2003
    Cincinnati, OH USA
    Question
    Quote Originally Posted by Zack
    Out of curiosity, what causes these leaks? Is it the line corroding and wearing, something coming loose, or something else?
    2006 Silverstone AWD Chevy Trailblazer SS
    -custom grind cam, kooks long tube headers, pcmformless tranny cooler, Vector CAI, Vector custom tune, Corsa catback, efans
    2004 Silver Birch Mercury Marauder
    -gone
    When I took delivery of my car, brand new just off the car carrier, I had a bad o-ring in one of the power steering hose connections. Sprayed red steering fluid all over the front of my engine bay. Quickly repaired by my dealer, but what a mess.
    2003 Mercury Marauder
    2007 Lincoln Town Car
    1993 Crown Victoria LX
    Nov 2003
    Milford Michigan
    Variable Assist Solenoid
    Another place that my 99 Crown Vic leaked was the power steering variable assist solenoid. I've replaced two of these, they last for about 60k miles, it wasn't leaking around the pipe fitting, it was actually through the solenoid assembly itself. I hope this issue has been fixed, I haven't seen any PS leaks so far in the Marauder.
    Got The Car Back
    Took the car in this morning. Just got it back. The service advisor says that there was a leak (crack?) in the PS pump itself, so they replaced the pump. New Allstate extended warranty picked up the cost (minus my $50.00 deductible). On the way back to the office, I stopped at a car wash to spray off any residue fluid that had leaked in the engine compartment (being very careful to use low pressure and to stay away from anything electronic). I want to be able to see if there any more leaks, and not have any old fluid dripping to confuse the situation. Funny how they made that PS unit to last exactly 36K before it failed!
    2003 MM 300A
    Born June 18, 2002
    Ford Racing 4.10's
    Silencer Removed
    Panther II Guest
    LOL, you'll find more things are "programmed" to go wrong right after the warranty is up. Always a good idea to go with Ford extended warranty. Glad you got the problem fixed.
    Sorta sucks that the dealer didn't clean the car up for you. My Mercury dealership are kind of sucky sometimes, but every time they've done anything messy on/around my engine they clean up nicely. I'm sure that when they open the hood on my car and are blinded by all the shiny black plastic they realize that they better keep it clean or there's going to be hell to pay.
  1. Drive line Critical speed
    Last Post: 07-12-2007, 06:11 PM
  2. KVR brakes and food for thought
    Last Post: 07-11-2006, 03:47 PM
  3. I'm on a transmission mission.
    By Mad4Macs in forum Shop Talk
    Last Post: 04-17-2004, 04:10 AM
  4. Trans Shifts and TC Lockup.....
    Last Post: 02-15-2004, 03:25 PM
  5. Good NEWS for future of RWD at Ford
    Last Post: 12-10-2003, 11:27 AM
