Page 12 of 18 FirstFirst ... 256789101112131415161718 LastLast
Results 166 to 180 of 265
Thread: Progress on build
  1. #166
    Sep 2013
    ST Louis
    Very nice
    Sent from my SM-G950U using Tapatalk
    Build# 1979/3214
    Year 2004
    300B
    Ext. DTR
    Int. Dark Char
    FINALLY BOOSTED!!!
  2. #167
    Oct 2003
    Beaufort, SC
    BEAUTIFUL work Marty & Co.!!
  3. #168
    Apr 2010
    South Florida
    Just got My covers back from coating.
  4. #169
    Jan 2006
    Northern California
    Awesome engine, sir. You and Marty think alike.
  5. #170
    Jan 2015
    Mishawaka, In
    Everything is looking good, here’s one that’s really close
  6. #171
    Jan 2006
    Northern California
    Another powerful, damn fine looking beast!
  7. #172
    Jan 2015
    Mishawaka, In
    Quote Originally Posted by Lowndex View Post
    Thanks, it’s in the car and ready for the start up tune for break in, it’ll be at MOs soon
  8. #173
    Jan 2006
    Northern California
    Quote Originally Posted by mm svt View Post
    I do not have much blower knowledge. But that looks like a 500 rwhp + setup to me.
  9. #174
    Jan 2015
    Mishawaka, In
    Progress on build
    Sure hope so,
    I guess I’ll do a run down on the mods, starting with a 99 teksid block
    .020 over, stroker crank, Manley rods, pistons from Carrillo 9cc dish Bullet series, Billet oil pump gears from Boundry, Moroso oil pan, 03 cobra oil pump pick up tube, p71 oil cooler and block adapter with oil filter relocation with -8 AN hoses and fittings, kooks long tubes ceramic coated, satin aluminum powder coated 03 cobra timing cover, lower intake, pulley bridge, idler bridge and inner cooler water adapter, original Marauder cam covers powder coated translucent blue, VMP Gen 2 TVS blower with Accufab throttle body, SCT BA 2600 maf, injector dynamics 1300x2 injectors, 300 amp alternator, killer chiller dual walbro 455 pumps, modified fuel hat for duel -8 lines out and -6 return, fore fuel rails, magnaflow pressure regulator, Kenn bell boost a pump, TREMEC T56 magnum, billet transmission yoke, custom drive shaft, larger universal joints, 31 spline axles and Eaton locker differential with ford racing 4:10 gears. The heads are the Marauder heads cnc ported and polished 31mm valves and seats bronze guides, new lifters, rockers with Crower Stage 3 blower cams, Marty and Jeff @ MOs took the time to add a start up tune and progress into a driver/ break in tune till it gets on the dyno very soon.
  10. #175
    Jan 2015
    Mishawaka, In
    Your car is going to be a show stopper, when it’s done you should probably take a year off and just hit car shows
  11. #176
    Apr 2010
    South Florida
    That car has a great nickname!
  12. #177
    Jan 2015
    Mishawaka, In
    What is the nickname?
  13. #178
    Money pit..... just like all the cars we mod
    Trilogy # 192 / T.S. 0012
  14. #179
    Jan 2006
    Northern California
    Marty has everything installed except wiring up the JRide system for the JRi coilovers. Engine start and test, Stainless Works full exhaust, all gauges working (at idle), etc. are done.
    Next is cleaning up the engine bay to look like it is headed to a car show, reinstall the stereo system (two batteries in trunk), install hood liner and led lights, etc.
    Then, drive it around to put some miles on the engine, tune the engine/blower/transmission, corner weight and take to a road track to properly adjust JRi settings. Final tune adjustments.
    Finally, detail and load on Reliable Carrier to come home (November 2019). The Marauder already has a home waiting for it - https://www.karparkauto.com/
    Yes, pictures to follow. I am waiting until the car is done and detailed.
  15. #180
    Hiram, Georgia
    Who said November???
  1. One HELLLL of a build!!
    By cer0413 in forum Community Discussion
    Last Post: 11-06-2016, 04:45 PM
  2. Replies: 23
    Last Post: 09-16-2007, 08:45 AM
  3. Build Date - Warranty Start Date
    By crouse in forum Community Discussion
    Last Post: 09-12-2006, 07:33 AM
  4. Electronics gurus...how can I build this?
    By Breadfan in forum The Lounge
    Last Post: 05-25-2006, 01:09 PM
  5. Tried But Didn't Get Build Sheet
    By 04MRADR in forum Test Forum
    Last Post: 03-06-2006, 01:08 PM
