WOW!....just wow!
My friggin' head hurts from reopening this thread!!
Sorry to the OCD OP for trying to help!
Might I suggest how and where you can put the rubber pegs and grommets young padawan!?
WOW!....just wow!
_______________________
I just threw an entire box of NOS pegs in the garbage. Sorry OP. I'll give you $8.00 for your car since it's missing pegs
I just realized that my Marauder's console is missing some rubber pegs!!!...
I'm selling the M'Fer!
Probably been two years since I even looked into my console, as it just holds the console air in place.
@EricGrain You have to understand some of these members are grumpy old men that are jerks and think just because they have a day one Marauder and a trilogy supercharger they are king of the hill. You just have to excuse these guys. There are some good guys on here. Fastblackmerc for example is a pleasant guy to deal with and is quite knowledgeable. It doesnt make a sh%t how long a member has had one or how old he/she was when they came out. Good luck finding the parts you need. I mostly depend on ebay for MM parts and have been quite successful at finding what i need.BEWARE THE MARAUDER TROLLS LOL
Thank you point made Get a job get a life hell get a wife
A couple two or three participants in this thread need to get a room the way they are rubbing all up and down on each other...
2004 silver birch, procharged, silvania silverstars, flowmaster 40's, mild tint, planet audio rear speakers....SOLD....
2003 black, 4.10's, lidio tune, flow master 40's with after cat delete, PIAA headlamps, Metco upper/lower control arms, Metco watts link, rear Addco anti sway bar, front grill gods head, tint is beyond aggressive....SOLD....
On the LookOut for #3... Have a Blue Baby in my sights. Open to suggestions on low mile blue/black offers.
I reckon we need some sensitivity training.
Not anger but annoyance some of you forum guys are under the illusion that the more posts you have the bigger your d#&k size i guess I dunno. Excuse me for not living on the computer and posting on the forum all day. Some of us actually work for a living.And @ Zack FYI Ford did have problems with certain 4.6 blocks reguardless of what you think you may know. I never said I was an expert on Marauders. I never said there was a problem with the Marauder 4.6 block. All i said was i was looking for a cobra cast iron block casting number. I didnt need your opinion about that you were baffled about why i would pick cast iron. True Terminators were cast iron and thats what I want.
