Results 1 to 15 of 25
Thread: Leak near passenger rear tire.
    Aug 2014
    Fort Benning, GA
    Guys, just did a 220 mile trip today and I got home and there is some type of oil ALL over my rear passenger tire and there is this dark fluid everywhere near the back of the vehicle; on the frame, the wheel, the tire, the brake caliper, tailpipe, etc.
    I checked my brake fluid and it's not low, pretty sure I'm not leaking brake fluid.
    My buddy says it's my axle seal.
    Thoughts?
    '03 300A Marauder, 107K miles, flowmaster 40 series mufflers, 2nd cats deleted, HID 6000K foglights, SilverStar Ultra's headlights, goodyear gatorback belt, K&N FIPK, K&N drycharger, SS inserts, spoiler, MSD COP's, Nitto Motivo's.
    Axle seal..
    Aug 2014
    Fort Benning, GA
    Great... Price? How hard to fix?
    Any Part numbers??
    Oct 2008
    Massachusetts
    Sadly that’s your axle seal, very common problem in 2003.
    Aug 2014
    Fort Benning, GA
    Should I go ahead and do 4.10's?
    Axle seal. Likely the axle shaft is bad also, so you'll need a seal, a shaft, and a new bearing. New parking brake shoes, too.
    The job isn't hard, but if you've never done it before you might wanna ask a friend who has to assist.
    Don't drive it any more than necessary and DON'T take any more 220-mile trips. If you run it out of fluid you'll be looking at a much bigger bill.
    Aug 2014
    Fort Benning, GA
    Roger, part numbers?
    Aug 2014
    Fort Benning, GA
    Thanks, guys.
    While it's open I'd do the 4.10's.
    Sep 2017
    sw minnesota
    C clip rear axle
    Gear lube has a particularly bad smell. Changing the axle seal on a "C" clip rear end is not that hard, a good project for a weekend warrior. A Haynes manual, or a quick search of you tube should reveal the details. But basically, a "C" clip inside the pumpkin retains the axle and keeps it from leaving the vehicle. You can see the occasional result of "C" clip failure along the road side... Ford 9 inch axles, and Dana use a bearing retainer at the outboard end and eliminate the "C" clip weakness. There are "C"clip eliminator kits on the market, but that's another job.
    You will have to dismantle the axle end, brake backing plate, etc. and then open the pumpkin. Removing the C clip doesn't require any special tools, but might need a little finagling. However, installing the new seal will require a seal driving tool, available at the auto parts store where you bought the seal (way under $10 bucks for a seal, I predict.). A seal puller is best to remove the old seal, but if you're VERY careful, something from your basic Harley Davidson tool kit will get it out. If the axle is damaged, feel with your finger for roughness, or a huge lip (some lipping is natural), but only a little. You will see clearly where the seal has been riding. Be sure to lube the axle shaft and the seal (petrolatum---Vaseline, or assembly lube, or just gear lube) when re-installing so that you don't tear the new seal, they are fragile that way. A good time to check the splines at the driven end of the axle... Be warned, gear lube is nasty stuff, so be sure and wear nitrile gloves.
    As for going to 4:10's, setting up tooth engagement, and rebuilding a posi is not a job for beginners, I would recommend a shop for that. (you will need some special tools, dial indicator, torque wrench, feeler gauges, machinist blueing, plus, to do an accurate job, a set of alignment shafts that hold the carrier in position are helpful (but tons of gear sets have been changed without them---just saying, a shop has access to specialized tools), etc. And, you will have to deal with....MATH, there, I said it)
    Sep 2017
    sw minnesota
    I forgot to mention it's a good time to inspect or replace bearings...
    Aug 2014
    Fort Benning, GA
    Shop is saying it is "wheel seal", does this sound about right?
    yes, but axle needs checked for a groove or it will leak again. 03 haz possible soft axles so a groove gets worn making bearing chew up seal
    Aug 2014
    Fort Benning, GA
    Pics of said groove or location?
    on axle shaft near end by tone ring. must pull axle to look. google marauder axle shaft groove
  1. Blow Out in Passenger Front Tire
    By rkk in forum Community Discussion
    Last Post: 06-17-2013, 06:49 PM
  2. Axle Seal Leak Passenger Side
    By VMARAUDER in forum Shop Talk
    Last Post: 05-22-2013, 09:59 AM
  3. Replies: 27
    Last Post: 02-18-2012, 10:16 AM
  4. Water leak for those with wet passenger floor
    By JimP in forum Community Discussion
    Last Post: 04-04-2010, 08:26 PM
  5. Help with back tire leak
    By testme in forum Shop Talk
    Last Post: 10-10-2007, 05:12 PM
